Auto-Populate - how to turn it off Vantage 8.03
Thanks Calvin, you just made me look like a WIZARD! That worked perfectly
and I'll remember that tip from now on. Thank you SO much.
Mike..
Calvin Dekker
Sent: Monday, July 15, 2013 10:07 AM
Subject: [Vantage] RE: Auto-Populate - how to turn it off Vantage 8.03
Mike -
If you access the form in Developer Mode, you should be able to click on the
user's personalization and delete it. This should remove the "auto
populate".
HTH,
Calvin Dekker
[cid:image001.jpg@01CE8143.136C4E20
<mailto:image001.jpg%4001CE8143.136C4E20> ]<http://www.codabears.com/>
630-672-7688 x1484
*Solutions for Epicor users.
"No trees were harmed during the sending of this message, however a large
number of electrons were terribly inconvenienced."
Behalf Of Mike Abell
Sent: Monday, July 15, 2013 9:04 AM
Subject: [Vantage] Auto-Populate - how to turn it off Vantage 8.03
Vantage gurus,
I have a user that turned on "auto populate" in the DMR Processing form and
now as soon as she goes into it, the system hangs as I'm guessing it's
trying to autopopulate thousands of records and it just hangs up. Is there a
way as an administrator I can somehow turn this off without having to go
into the user's DMR form (as I can't get in there at the moment as it just
hangs up Vantage)?
Mike Abell
Information Technology Manager
Flexial - BOA Group - Cookeville, Tennessee
Office: 931.432.1853 ext 302
Mobile: 615.418.3055
email: MAbell@... <mailto:MAbell%40flexial.com>
Vantage gurus,
I have a user that turned on "auto populate" in the DMR Processing form and now as soon as she goes into it, the system hangs as I'm guessing it's trying to autopopulate thousands of records and it just hangs up. Is there a way as an administrator I can somehow turn this off without having to go into the user's DMR form (as I can't get in there at the moment as it just hangs up Vantage)?
Mike Abell
email: MAbell@...
Mike -
If you access the form in Developer Mode, you should be able to click on the user's personalization and delete it. This should remove the "auto populate".
HTH,
Calvin Dekker
[cid:image001.jpg@01CE8143.136C4E20]<http://www.codabears.com/>
630-672-7688 x1484
"No trees were harmed during the sending of this message, however a large number of electrons were terribly inconvenienced."
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mike Abell
Vantage gurus,
Mike Abell
email: MAbell@...<mailto:MAbell%40flexial.com>
