Auto-Printing to Zebra Label Printer
We had to calibrate the printer to the correct print stock and it worked. If you are still having problems look up calibration in the Zebra manual.
I am looking to setup auto-printing to a zebra label printer. When I print the label from Vantage without using autoprint, the label prints out fine. However, when I enable auto-printing the label prints out but the text on the right-hand side of the label (about an inch) is being cut off.  Has anyone seen something similar to this? Any ideas on how I can get this resolved?
 Dustin Biniek
UMC, Inc.
DustinB@...
We do quite a bit of auto printing here. It is interesting to note that
you will see minor variations from print direct from vantage and auto
print. My first question would be what are you using as a label
designer? Crystal or Bartender? We use crystal (because Epicor doesn't
need anymore of our money), so I'm most familiar with that (ok, only
that). If you are running crystal make sure you define stocks in the
printer properties to reflect your label size and then pick that
particular stock in the page setup within crystal.
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site)
Of melissa hietala
Sent: Monday, March 23, 2009 11:45 AM
Subject: [Vantage] Auto-Printing to Zebra Label Printer
Dustin Biniek
UMC, Inc.
DustinB@... <mailto:DustinB%40ultramc.com>
Thanks for the response Rob,
We are using Crystal as well.  I've adjusted the label size as you suggested but I am still seeing the same results. I've tried all sorts of different settings within "printer maintenance", but nothing I adjust seems to have an impact. Any other thoughts on what may be causing this?
Thanks for your help,
 Dustin Biniek
Sent: Monday, March 23, 2009 2:02:56 PM
Subject: RE: [Vantage] Auto-Printing to Zebra Label Printer
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg com/>
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of melissa hietala
To: vantage@yahoogroups .com
Dustin Biniek
UMC, Inc.
DustinB@ultramc. com <mailto:DustinB% 40ultramc. com>
Just a stab in the dark, or a WAG....
When you print label normally you print fom a workstation and the logged on user has printing preferences set up...
When you auto print, the job originates from the server running under the 'user' set up for the admin service logon ??
maybe you can logon to server as the admin service logon account and check printing preferences on the zebra printer then...
I had a kind of similar weird problem with CorVu scheduled reports output to pdf run from a bat file. I had to set print preferences for the logon account that was used to run the bat file
> Â Dustin Biniek
> From: Rob Bucek <rbucek@...>
> Rob Bucek
> FAX: 715-284-4084
> Of melissa hietala
> Thanks,
> Dustin Biniek
> UMC, Inc.
Dustin,
I remember having a problem a few years ago with a Zebra printer that
was only printing half of the label and I had to change a setting on the
printer. It was printing 4 x 2 and I was printing 2 x 4 or the other
way around. I don't remember the exact details now.
Linda
Of melissa hietala
Sent: Wednesday, March 25, 2009 11:48 AM
Subject: Re: [Vantage] Auto-Printing to Zebra Label Printer
Dustin Biniek
From: Rob Bucek <rbucek@... <mailto:rbucek%40dsmfg.com> >
Rob Bucek
FAX: 715-284-4084
Behalf
Of melissa hietala
Dustin Biniek
UMC, Inc.
Did you call for the stock by name on the setup page in the crystal
report? We have noticed sometimes that minor adjustments don't behave
as expected. Linda's email struck a mental note. The paper orientation
is not like you might think. Switch your width by height measurements
as she mentioned. I also remember having that problem when we started
as well, obviously a distant memory now..
Rob Bucek
FAX: 715-284-4084
Of melissa hietala
Sent: Wednesday, March 25, 2009 10:48 AM
Dustin Biniek
Rob Bucek
FAX: 715-284-4084
Behalf
Of melissa hietala
Dustin Biniek
UMC, Inc.
I adjusted the print settings on the server and it seems to have fixed the problem. Thank you all for your input! It has saved me a lot of time and a major headache! :-)
Â
Dustin Biniek
Sent: Wednesday, March 25, 2009 6:13:48 PM
Subject: [Vantage] Re: Auto-Printing to Zebra Label Printer
> We are using Crystal as well.  I've adjusted the label size as you suggested but I am still seeing the same results. I've tried all sorts of different settings within "printer maintenance" , but nothing I adjust seems to have an impact. Any other thoughts on what may be causing this?
> Â Dustin Biniek
> Rob Bucek
> FAX: 715-284-4084
> From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf
> Of melissa hietala
> Thanks,
> Dustin Biniek
> UMC, Inc.
