Todd,
Also make sure to check closed and open jobs-if a closed job is marked as a
template and someone is using it with an auto-receive box-that one will bite
you too.
Lydia
Sent: Friday, November 17, 2000 5:42 AM
To: vantage@egroups.com
Subject: RE: [Vantage] Auto Receive to Inventory Flag Location
Todd,
Also check in PartRev.AutoRecOpr if you use BOM's. We found that some of
our BOM's had the auto receive box checked as well causing recurring
instances of the same problem you are looking for.
John Yohannan
BMC
Sent: Thursday, November 16, 2000 3:35 PM
To: 'vantage@egroups.com'
Try looking in the JobAsmbl.AutoRecOpr
Sent: Thursday, November 16, 2000 2:09 PM
Subject: [Vantage] Auto Receive to Inventory Flag Location
I am going blind trying to read through the Data Dictionary to find where
"Auto Receive to Inventory" on a Job Operation is stored. We do not use
this at all but occasionally it gets "checked" on the job operation entry
screen. I am trying to write a quickie report to show all operations that
have this set so we can "fix" them before the job is done. Does anyone know
where this is stored?
-Todd Caughey
Harvey Vogel Mfg. Co.
you too.
Lydia
Todd,
John Yohannan
BMC
-Todd Caughey
