Autocomplete Parent Task
Thanks for the information! Would you be able to provide the query needed please? I am not too good with the query side of Method Directives...
--- In vantage@yahoogroups.com, Waffqle <waffqle@...> wrote:
> You'll need to create a preprocessing directive on Task.Update (or whatever
> the actual business object is called. Enable tracing and complete a task
> manually to see just which one you need.)
> Just query for other uncompleted rows with the same parent; if you don't
> find any, close the parent.
> Tada!
> On Tue, Apr 19, 2011 at 6:42 AM, Ian <ianwhardy@...> wrote:
> > Hi,
> > Is it possible to autocomplete a parent task when all sub related tasks are
> > completed?
> > I'm assuming it would be done using a BPM, but I'm not sure how it would be
> > done.
> > Thanks in advance for any and all help!
Hi,
Is it possible to autocomplete a parent task when all sub related tasks are completed?
I'm assuming it would be done using a BPM, but I'm not sure how it would be done.
Tada!
> Hi,
> completed?
> done.
