Not sure what AutoHotkey is, but if all you want to do is open Vantage and automatically logon, Single Sign On (SSO) is supported on at least 8.03.400 and up. (maybe earlier too, that's just where I started). In Company Maintenance > User, set the Domain and Domain User ID. Then edit the .mfgsys file associated with your Vantage shortcut in your Client\Config directory. Change the value to true, <SingleSignOn value="true" bool="" /> under the <userSettings> section.
--- In vantage@yahoogroups.com, "RICH WAGNER" <rwagner@...> wrote:
> I trying to learn to use AutoHotkey. Does anyone have a simple script they can share that open and logs you into Vantage?
> Thanks,
> Rich Wagner
> [cid:image001.jpg@...]
> 2148 Century Drive
> Jefferson Hills, PA 15025
> Phone: (412) 384-3100 x159
> Fax: (412) 384-2033
> www.bawplastics.com<http://www.bawplastics.com/>
