Dear Team,
I tried to automate the Miscellaneous values binding in APInvoiceEntry in Create the new receipt line. but i got the server error. The below BPM code and error messge. Kindly, help me.
string tmpPackNo = string.Empty;
int tmpPoNo = 0, tmpPoLne = 0, tmpVendorID = 0, tmpVendorNum = 0;
int tmpVenNo = 0;
string tmpRcvPackNo = string.Empty;
string tmpInvocieNo = string.Empty;
string tmpMiscCode = string.Empty;
decimal tmpMiscAmt = 0;
string tmpEmpty = string.Empty;
int tmpval = 0;
decimal tmpVal1 = 0;
bool tmpFalse= false;
string tmpGrp = string.Empty;
string purMiscCode = string.Empty;
InfoMessage.Publish(“1”);
var ttSelRctRow = (from s in ttAPSelectedRcptLines where (s.Company == Session.CompanyID) select s).FirstOrDefault();
//foreach(var ttSelRctRow in(from s in ttAPSelectedRcptLines where (s.Company == Session.CompanyID) select s))
if(ttSelRctRow != null)
tmpPackNo = Convert.ToString(ttSelRctRow[“PackSlip”]);
tmpInvocieNo = Convert.ToString(ttSelRctRow[“InvoiceNum”]);
var APInvHead = (from row in Db.APInvHed where row.Company == Session.CompanyID && row.InvoiceNum == tmpInvocieNo select row).FirstOrDefault();
if(APInvHead !=null)
tmpVenNo = Convert.ToInt32(APInvHead[“VendorNum”]);
tmpGrp = Convert.ToString(APInvHead[“GroupID”]);
InfoMessage.Publish(“2”);
InfoMessage.Publish("Vendor Num " + tmpVenNo.ToString());
InfoMessage.Publish("invoice Num " + tmpInvocieNo.ToString());
InfoMessage.Publish(“4”);
InfoMessage.Publish("Vendor Num " + tmpPackNo.ToString());
Erp.Contracts.APInvoiceSvcContract APInvcBO = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.APInvoiceSvcContract>(Db);
APInvcBO.GetByID(tmpVenNo,tmpInvocieNo);
Erp.Tablesets.APInvoiceTableset TblSet = new Erp.Tablesets.APInvoiceTableset();
/*foreach(var RcvMiscRow in(from Misc in Db.RcvMisc where (Misc.Company == Session.CompanyID && Misc.PackSlip == tmpPackNo) select Misc).ToList())
tmpMiscCode = Convert.ToString(RcvMiscRow["MiscCode"]);
tmpMiscAmt = Convert.ToDecimal(RcvMiscRow["DocActualAmt"]);
//var RcvMiscRow = (from Misc in Db.RcvMisc where (Misc.Company == Session.CompanyID && Misc.PackSlip == tmpPackNo) select Misc).FirstOrDefault();
foreach(var RcvMiscRow in(from Misc in Db.RcvMisc where (Misc.Company == Session.CompanyID && Misc.PackSlip == tmpPackNo) select Misc))
//if(RcvMiscRow != null)
// if(tmpMiscCode != null && tmpMiscAmt > 0)
tmpMiscCode = Convert.ToString(RcvMiscRow[“MiscCode”]);
tmpMiscAmt = Convert.ToDecimal(RcvMiscRow[“DocActualAmt”]);
//CallContext.Current.ExceptionManager.AddBLException("Misc Code - " +tmpMiscCode.ToString());
//CallContext.Current.ExceptionManager.AddBLException("Misc Amt - " +tmpMiscAmt.ToString());
InfoMessage.Publish("Misc Code - " + tmpMiscCode.ToString());
//var ttPurMiscRow = (from P in Db.PurMisc where (P.Company == Session.CompanyID && P.MiscCode == tmpMiscCode) select P).FirstOrDefault();
foreach(var ttPurMiscRow in(from P in Db.PurMisc where (P.Company == Session.CompanyID && P.MiscCode == tmpMiscCode) select P))
if(ttPurMiscRow != null)
purMiscCode = Convert.ToString(ttPurMiscRow["MapChargeID_c"]);
InfoMessage.Publish("Group Name - " + tmpGrp.ToString());
InfoMessage.Publish("Map Misc Code - " + purMiscCode.ToString());
InfoMessage.Publish("Misc Amt - " + tmpMiscAmt.ToString());
APInvcBO.GetNewHdrCharge(ref TblSet,tmpVenNo,tmpInvocieNo,false);
//APInvcBO.ChangeMiscCode("RFR1","APIHAPInvMsc",ref TblSet);
//APInvcBO.ChangeMiscAmt(100,"APIHAPInvMsc",ref TblSet);
APInvcBO.ChangeMiscCode(purMiscCode,"APIHAPInvMsc",ref TblSet);
APInvcBO.ChangeMiscAmt(tmpMiscAmt,"APIHAPInvMsc",ref TblSet);
InfoMessage.Publish("5");
TblSet.APIHAPInvMsc[0].Company = Session.CompanyID;
InfoMessage.Publish("6");
TblSet.APIHAPInvMsc[0].GroupID = tmpGrp;
TblSet.APIHAPInvMsc[0].VendorNum = tmpVenNo;
TblSet.APIHAPInvMsc[0].InvoiceNum = tmpInvocieNo;
TblSet.APIHAPInvMsc[0].InvoiceLine = 0;
TblSet.APIHAPInvMsc[0].MiscCode = purMiscCode;
TblSet.APIHAPInvMsc[0].MiscAmt = tmpMiscAmt;
TblSet.APIHAPInvMsc[0].RowMod = "A";
InfoMessage.Publish("7");
APInvcBO.UpdateMaster(ref TblSet,tmpGrp,"APIHAPInvMsc",false,false,false,false,out tmpVal1,out tmpFalse,out tmpEmpty,out tmpEmpty,out tmpEmpty,out tmpFalse,out tmpFalse,out tmpEmpty);
//break;
I received the following error
Error:
Server Side Exception
A server error occurred. Review the server event logs for details.
Error Detail
Correlation ID: 308ed503-7981-4e91-930f-7a6e10bedb2e
Description: A server error occurred. Review the server event logs for details.
Program: Epicor.System.dll
Method: ProvideFault
Line Number: 33
Column Number: 17
Server Trace Stack: at Epicor.Hosting.Wcf.ErrorHandler.ProvideFault(Exception error, MessageVersion version, Message& fault) in C:_Releases\ICE\UD10.2.600.11FW\Source\Framework\Epicor.System\Hosting\Wcf\ErrorHandler.cs:line 33
at System.ServiceModel.Dispatcher.ErrorBehavior.ProvideFault(Exception e, FaultConverter faultConverter, ErrorHandlerFaultInfo& faultInfo)
at System.ServiceModel.Dispatcher.ErrorBehavior.ProvideMessageFaultCore(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage8(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.ProcessError(Exception e)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result)
at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
at System.ServiceModel.Channels.SecurityChannelListener1.ReceiveItemAndVerifySecurityAsyncResult
2.InnerTryReceiveCompletedCallback(IAsyncResult result)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.APInvoiceImpl.InvoiceSelectedLines(APInvReceiptBillingDataSet ds, String& opLOCMsg)
at Erp.Adapters.APInvoiceAdapter.InvoiceSelectedLines(String& opLOCMsg)
