Automated PO Receipts
Does anyone use an automated method to scan delivery paperwork to enter the Receipt Entry Details into Kinetic? If you do, what method do you use? :thinking:
We scan after the fact. We found there are to many issues trying to automate. Would be interested to hear if there are some creative ways to get around our roadblocks. (Qty difference on PO, damaged goods, and inspection process)
I agree, our Ops people are saying there are tools out there that will do it but there are so many variables involved
We thought about this and we’ve got a lot of issues with some supplier, mainly for raw materials. There are endless mismatches : ordered 20ft length but supplier sent 24ft length, packing slip does not match received items, non conformance, qty difference, etc.
Maybe automation could be scoped to some approved and reliable supplier/product, such as fasteners and other unit items, which are quite reliable.
I would like to hear some success stories.
Thanks for the response as it is also helpful to understand if people have looked at it and the reasons they may have decided against doing it.
I was thinking about this, and maybe the workflow could be the following:
  • Goods are received with packing slip
  • Employee inspects/review the goods and paperwork
  • If everything is fine (most of the time), sends the paperwork to automation
  • If there is something wrong, manual entry
This way, maybe 60%-70% of receipts can be automated. And the workflow provides an incentive for the company to select suppliers that are reliable, since receiving and paperwork handling costs are not considered in most purchasing decisions.
Funnily enough that is what we were just discussing internally, do the checks first and then the process.
And for the automation itself, I think AI is great. I’ve got my own small consulting business on the side and I automated my payables. I just send a picture of the invoice to a specific email address and each night an AI agent process the emails. It read the pictures, creates an entry in my journal. Fill the data (amount, date, supplier, taxes…) and stores the original picture for reference. I then sends me a report in the morning. So far, 100% success rate since implementation.
I would like to test something similar for receipts. Send the packing slip to a queue somewhere (UD Table ?), then let AI process it by calling a specific Epicor Function library that contains all the logic. Then monitor the failures and ajust.
But I still got some frictions in my mind on using AI agent with Epicor. I still got questions and fear around cybersecurity in general. How do I scope the AI so it only have a very limited access to what’s needed ? How can I prevent users to go rogue ? I guess Jose’s Cutova might be the solution, I just need to investigate
Yeah you are right to be cautious and i have been the same. I have started to use Automation Studio over the last couple of months, have done the PO Approval process so it is fully automated by emails and i am now looking at the PO Requisition process using UD tables, BPMS and automation studio so that we can have a full blown approval workflow based around GL Accounts that can not only be used for that but all AP Invoices.
If you are wanting to catch the issues that could occur that are not tracked within the paperwork then a possible solution is to have a program which when scanning the paperwork it looks for specific fields and then populates them into a text box. From there a person could either change the value that does not match or just send it off without changed. The program would need to utilize REST calls to transfer the data into Epicor but that does give an airgap for the AI since it doesn’t need access to the system only the pdf, and the REST calls can be scoped out to the specific Method or Function needed to process the PO.
This does mean that each PO would need to be reviewed but that is the tradeoff of not being able to fully trust the data. You could even have it send them off on a batch and have the AI flag any it thinks are off or you do give it access to some of the data in the system so it can compare what exists already to what is trying to be added.
Which kind of defeats the objuct of what they are trying to achieve in reducing transaction count. In my mind, they have to check the PO match etc.. so wanting to automate the receipt process above and beyond what currently happens will mean they would need to do extra checking and therefore negate that time saving :thinking:
I agree if you are just wanting to have it be fully automated then the extra steps would slow that down. I think this logic could still be used where you can just remove the textbox checks and still have the data sent via REST calls after the AI has parsed it. I think that works because it means only the fields you want to be updated get updated.
We implement a DGX Spark with Qwen3.8-27B for scanning packing lists among other things, and previously used Qwen3.6 and DeepSeek-OCR.
The process ties into Epicor and automates filing of documents and attachment into the system. It could easily do the verification process but some things should still be manual.
We built a portal for simple processing of the data that is scanned.
