Back flush labor
Babette,
These are not separate fields but options on a drop down list. Do the following:
1. Go to the Job-Operation screen
2. Field Label is LABOR ENTRY - Drop down list options are Quantity ONLY, Time and Quantity, Backflush
Exceptions:
a. If you tick the box Auto Receive to Inventory (on lower right hand of the screen) the Backflush option will not be available.
HTH,
Gil Amilbangsa
Australian Healthcare Equipment - Murphy Furniture
gil.amilbangsa@...
Sent: Tuesday, 17 December 2002 4:15 AM
Subject: [Vantage] Back flush labor
Hello everyone:
We have numerous short operations which we periodically time-study then enter the estimates on the parts.
From day-one with Vantage we planned to 'backflush' labor.
Finally with 5.1 we can.
Yet , now I am having trouble implementing it.
The Help File says there are two fields on the Job-Operation which I do not see:
1) Back Flush Cost
2) Report Quantity
Is anyone else currently back flushing labor?
If so, please give me some details on how it works for you.
Write on or off list.
Thank you
BW
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.226.9747 ext 235
906.228.0951 fax
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=228862.2128520.3581629.1925585/D=egroupweb/S=1705007183:HM/A=1339748/R=0/*http://click.atdmt.com/COL/go/yhxxxchm00400063col/direct/01/&time=1040062502607665>
<http://us.adserver.yahoo.com/l?M=228862.2128520.3581629.1925585/D=egroupmail/S=:HM/A=1339748/rand=178899093>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Hello everyone:
1) Back Flush Cost
2) Report Quantity
Thank you
BW
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
Hi Babette,
We don't use backflushing, but I did some testing with it. As a result of the testing, I have a document that itemized the steps we were going to use to accomplish backflushing. Below is the list we created.
Troy Funte
Liberty Electronics
Steps to Setting up BackFlushing with Single Step router
1.. Select a top level part to configure.
2.. Print the BOM Listing Report (Production/ABOM/Reports/BOM Listing)
3.. Set each part in the BOM to be backflushed
1.. Enter Part Master Maintenance by selecting Production/Job Management/Master File Maintenance/Part
2.. Enter one by one each component part in the search filed
3.. Double-Click the part number.
4.. In the Part maintenance screen, click Inv/Purch. button.
5.. In the Inventory Purchasing Part Plant maintenance screen, click the BackFlush check box and OK and OK.
6.. Do this with each part on the BOM.
4.. Update the Router to a Single step.
1.. Go to Part Maintenance (Production/ABOM/Master File Maintenance/Part)
2.. Select the Manufactered part that you are going to Backflush material for
3.. Select Revision/BOM from the menu.
4.. On the Part Rev screen, click the Update button
5.. Uncheck the Approved check box.
6.. Select an operation in the router and click Delete for each step you want to eliminate, leaving the final operation in the router as the single complete step.
7.. Check the Approved check box and click OK.
8.. Enter a description of the change and click OK.
9.. Click close.
5.. Create a new Job
1.. Select Job Entry from Production management/Job Management/General Operations/Job Entry.
2.. In the Job Entry screen, select Job/add from the menu.
3.. Enter a job number, or click next job and click OK.
4.. Enter the top level part from step one above in the Job header Maintenance screen.
5.. Enter a Req. By Date
6.. Click Add at the bottom of the Job Header Screen to add a Quantity.
7.. Enter a Quantity, and check the "Make to Stock" radio button, press OK.
8.. Click OK to exit Job Header maintenance
9.. Back in the Job Entry screen, link a BOM to the job by selecting Get Details from the menu.
10.. Select the correct Manufactured part and click OK and Yes.
11.. Select Scheduling/Job Scheduling from the menu.
12.. Click the Forward radio button, and enter a Start Date (then wait several minutes - the screen will not respond during this time).
13.. Select Links/comments from the menu and enter a comment.
14.. In the Manufacturing Links screen, click Job Entry from the Right-Center of the screen.
15.. Back in the Job Entry screen, select each material component of the job and double-click it.
16.. Enter (or search for) the Related Operation that you want to trigger the BackFlush (there should be only one now).
17.. Do step p & q above for each material component.
18.. Check the Engineered box and the Released box and enter a comment.
19.. Exit the Job Entry Screen.
6.. Run Labor against the Operation so that the backflushing occurs
1.. Select Job Adjustment from Production/Job management/General Operations/Job Adjustment.
2.. Click the Labor Adjustment button.
3.. Enter the job number and the operation.
4.. Enter an Employee ID
5.. Enter a quantity for that operation. Don't check complete or opr complete.
6.. Enter hours and costs, etc. Click OK.
The materials should now be issued to the job.
It's just that simple!!!!!
----- Original Message -----
Sent: Monday, December 16, 2002 1:14 PM
Hello everyone:
1) Back Flush Cost
2) Report Quantity
Thank you
BW
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
ADVERTISEMENT
