Backflush table name?
In E9 there used to be a table that held the jobs that needed to be backflushed and I can’t remember the name of the table and I’m trying to find it in E10.
JobMtl will show you what will be backflushed…will also show you what wont be. Is this the table you are referring to, I wasn’t aware there was a table that just showed parts to be backflushed.
I remember that when BF would fail there was a table where I would looked to see what hadn’t been BF and possibly which Jobs were causing the issue and I don’t think it was the JobMtl table.
This table has a field called Issued Complete, as well as Required Qty and Issued Qty. This should tell you what has and hasn’t worked
