Backflushing when using "pulled" qty on jobs
Are you using "pull quantity" for subassemblies that you want to pull from stock instead?
What version are you on?
Â
Jim Eliason
L&M Radiator, Inc.
Â
Â
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Wednesday, October 24, 2012 12:00 PM
Subject: [Vantage] RE: Backflushing when using "pulled" qty on jobs
Â
Manasa, when you manually close the job there is a checkbox to backflush and we selected it but it appeared to do nothing...
Mike Abell
Systems Analyst / Network Administrator
Flexial - BOA Group - Cookeville, Tennessee
Office: 931.432.1853 ext 302
Mobile: 615.418.3055
email: mailto:MAbell%40flexial.com
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of Manasa Reddy
Sent: Wednesday, October 24, 2012 11:29 AM
To: mailto:vantage%40yahoogroups.com
One question, exactly how are you back flushing "manually"? Do you still record the labor?
We do this and I have no problems.
M. Manasa Reddy
mailto:manasa%40weldcoa.com<mailto:manasa%40weldcoa.com><mailto:mailto:manasa%40weldcoa.com<mailto:manasa%40weldcoa.com>>
630.806.2000 x1515
From: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Mike Abell
Sent: Wednesday, October 24, 2012 11:22 AM
To: mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com>
Subject: [Vantage] Backflushing when using "pulled" qty on jobs
Vantage gurus,
We are having an issue that when we create assemblies on jobs and use a "pull quantity" for the assemblies that match the required qty, and then we "manually" close the job and tell it to "backflush", we see no transactions that anything is getting backflushed. Is this a bug or are we missing something?
Mike Abell
email: mailto:MAbell%40flexial.com<mailto:MAbell%40flexial.com><mailto:MAbell%40flexial.com>
Vantage gurus,
Mike Abell
email: MAbell@...
M. Manasa Reddy
manasa@...<mailto:manasa@...>
630.806.2000 x1515
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mike Abell
Vantage gurus,
Mike Abell
email: MAbell@...<mailto:MAbell%40flexial.com>
Our backflushing occurs after the completed quantity is entered on the
final operation I believe.
Josh Serwe
Manager of Warehouse & Logistics
920.437.6400 Ext. 330
"There's only one thing more painful than learning from experience, and
that is not learning from experience."
Dr. Laurence Peter
<http://www.wisconsinconverting.com>
This is what we would like to go to as well - so it is all real-time. Unfortunately, not been able to make this work so far. The consultant has to look into it.
I want Epicor to backflush when the completed quantity is entered on the final operation and not when the job is closed. That would defeat the purpose of real-time.
Anyone have any tips of what to look for in the setup?
Kimberly Onstott
Cost Accounting Manager
Saint-Gobain Solar Glass, N.A.
4320 S. Cotton Lane Ste 300
Goodyear, AZ 85338
623-882-9533 x6003
Kimberly.Onstott@...<mailto:Kimberly.Onstott@...>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joshua Serwe
Sent: Wednesday, October 24, 2012 9:33 AM
Josh Serwe
Dr. Laurence Peter
Kimberly...setup is somewhat easy...what makes it hard is the number of parts you have and operations on your bills. AND gets complicated if you have sub contract ops....but it still works!
Basic setup...all ops are set to back flush and the last op is set to quantity only. Look at the operations on a job...there is a field called "Labor Entry" This is the where you set the "back flush" or "Quantity only" You record the quantity only op literally in labor entry screen.
Once that is finished, then you look at the job in the Job Closing screen. Make sure all materials did back flush AND ONLY THEN do you back flush and complete the job. If you have a material that did not back flush because someone forgot to mark the part as back flush, issue the material first and the go back and complete your job.
Hope this makes sense...otherwise ask anything you want. This works well for us because we do not have the man power to record ALL labor ALL the time.
M. Manasa Reddy
630.806.2000 x1515
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Onstott, Kimberly
Sent: Wednesday, October 24, 2012 11:40 AM
Kimberly Onstott
Goodyear, AZ 85338
623-882-9533 x6003
Kimberly.Onstott@...<mailto:Kimberly.Onstott%40saint-gobain.com><mailto:Kimberly.Onstott@...<mailto:Kimberly.Onstott%40saint-gobain.com>>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Joshua Serwe
Josh Serwe
Dr. Laurence Peter
Mike Abell
email: MAbell@...
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Manasa Reddy
M. Manasa Reddy
manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa@...<mailto:manasa%40weldcoa.com>>
630.806.2000 x1515
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Mike Abell
Vantage gurus,
Mike Abell
email: MAbell@...<mailto:MAbell%40flexial.com><mailto:MAbell%40flexial.com>
The Backflush labor process has to be running. You can start manually, but will want it to be in your startup group, so it starts when the appservers do.
you will see the results in job tracker.
Greg
Sent: Wednesday, October 24, 2012 1:00 PM
Mike Abell
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Manasa Reddy
M. Manasa Reddy
manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com>>
630.806.2000 x1515
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Mike Abell
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
Vantage gurus,
Mike Abell
email: MAbell@...<mailto:MAbell%40flexial.com><mailto:MAbell%40flexial.com><mailto:MAbell%40flexial.com>
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Where did you check it as backflush? If it is checked on the part plant
prior to the job material being added it should default on the material.
Do you have a backflush bin set up at the resource level?
Josh Serwe
Dr. Laurence Peter
Yep, Mike, that has to run as well.
The check box does nothing unless you have all of the setup I am talking about.
Parts have to be checked as back flush. This is on the plant tab of each part. And make sure you are not using this material on job that do NOT back flush.
Then you have to have your bills set up the way I explained it to Kimberly.
Regardless of the process running you still have to record labor.
Then this box will work.
Yes it took us 6 months of utter crap before I found the right resource at Epicor to give us this explanation!
M. Manasa Reddy
630.806.2000 x1515
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Greg Payne
Sent: Wednesday, October 24, 2012 12:58 PM
Greg
Mike Abell
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Manasa Reddy
M. Manasa Reddy
manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:manasa@...<mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com><mailto:manasa%40weldcoa.com>>
630.806.2000 x1515
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Mike Abell
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
Vantage gurus,
Mike Abell
email: MAbell@...<mailto:MAbell%40flexial.com><mailto:MAbell%40flexial.com><mailto:MAbell%40flexial.com><mailto:MAbell%40flexial.com>
Kimberly, set your operations labor reporting as backflush in your MOM. For your last operations, set it to quantity only and/or time and quantity and check it as "final operation" Make sure your "backflush labor process" is set to run on a continuous basis. When you report on the last operation, the backflush labor process runs and looks for any previous operations that are marked as backflush and will automatically close those operations
Sent: Wednesday, October 24, 2012 12:39 PM
Â
Kimberly Onstott
Goodyear, AZ 85338
623-882-9533 x6003
mailto:Kimberly.Onstott%40saint-gobain.com<mailto:mailto:Kimberly.Onstott%40saint-gobain.com>
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of Joshua Serwe
Josh Serwe
Dr. Laurence Peter
