# Backup problems with 4.0
**Category:** [Yahoo Archive](https://www.epiusers.help/c/yahoo-archive/9)
**Created:** 2001-04-27 19:55 UTC
**Views:** 438
**Replies:** 0
**URL:** https://www.epiusers.help/t/backup-problems-with-4-0/2770
## Post #1 by @system
I keep getting a Dr. Watson error when running Epicors "Backvan.bat".
"An application error has occurred and an application error log is being generated. _mprshut.exe Exception: divide by zero (0xc0000094), Address: 0x00416a76"
IN addition, It shuts down the 4.0 database in Procontrol.
It puts the "40backup.vn" file into the f:\epicor\backup folder with 0 bytes.
When I run the probkup command from the command prompt, the text reads...
"PROGRESS PATCH Version 9.0B44 as of October 31, 2000
Blocking factor must be greater than bi block size (652)
Bi block size is 8192 (672)"
Then it goes to the command prompt.
In this case, Dr. Watson says: "_mprshut.exe Exception: divide by zero (0xc0000094), Address: 0x00416a76)
Anyone have a clue?
Troy Funte
Liberty Electronics
**Canonical:** https://www.epiusers.help/t/backup-problems-with-4-0/2770
**Original content:** https://www.epiusers.help/t/backup-problems-with-4-0/2770
