good morning.
I am getting a bad sql error when DISPLAYING any field from a connected table, specifically the GLAcctDisp
I understand, typically, BAQ SQL is a result of bad data/calculation.
But I don’t get why, there is NO error, when the table is connected and i do NOT display any fields from it.
The error occurs ONLY when i try to add ANY field from that table into the display - including company.
is there something else occurring deep down on a table join when a display field is requested (besides the obvious show the field)
select
[SalesTer].[TerritoryID] as [SalesTer_TerritoryID],
[SalesTer].[TerritoryDesc] as [SalesTer_TerritoryDesc],
[Vendor].[VendorID] as [Vendor_VendorID],
[Vendor].[Name] as [Vendor_Name],
[APInvHed].[sgcPGOrder_c] as [APInvHed_sgcPGOrder_c],
[APInvDtl].[InvoiceNum] as [APInvDtl_InvoiceNum],
[APInvHed].[InvoiceDate] as [APInvHed_InvoiceDate],
[APInvHed].[ApplyDate] as [APInvHed_ApplyDate],
[APInvDtl].[InvoiceLine] as [APInvDtl_InvoiceLine],
[TranGLC].[BookDebitAmount] as [TranGLC_BookDebitAmount],
[APInvHed].[DueDate] as [APInvHed_DueDate],
[APInvDtl].[Description] as [APInvDtl_Description],
[PurTerms].[Description] as [PurTerms_Description],
[APInvHed].[REFPONum] as [APInvHed_REFPONum],
[APInvDtl].[AllocDeferred_c] as [APInvDtl_AllocDeferred_c],
[APInvHed].[EntryPerson] as [APInvHed_EntryPerson],
[APInvHed].[Company] as [APInvHed_Company],
[APInvHed].[InvoiceAmt] as [APInvHed_InvoiceAmt],
[Vendor].[GroupCode] as [Vendor_GroupCode],
[TranGLC].[GLAccount] as [TranGLC_GLAccount],
[GLAcctDisp].[GLAcctDisp] as [GLAcctDisp_GLAcctDisp],
[GLAcctDisp].[AccountDesc] as [GLAcctDisp_AccountDesc],
[GLAcctDisp].[GLShortAcct] as [GLAcctDisp_GLShortAcct]
from Erp.APInvHed as APInvHed
inner join Erp.APInvDtl as APInvDtl on
APInvHed.Company = APInvDtl.Company
and APInvHed.VendorNum = APInvDtl.VendorNum
and APInvHed.InvoiceNum = APInvDtl.InvoiceNum
and ( APInvDtl.AllocDeferred_c = True )
left outer join Erp.APInvExp as APInvExp on
APInvExp.Company = APInvDtl.Company
and APInvExp.VendorNum = APInvDtl.VendorNum
and APInvExp.InvoiceNum = APInvDtl.InvoiceNum
and APInvExp.InvoiceLine = APInvDtl.InvoiceLine
left outer join Erp.TranGLC as TranGLC on
APInvExp.Company = TranGLC.Company
and APInvExp.VendorNum = TranGLC.Key1
and APInvExp.InvoiceLine = TranGLC.Key3
and APInvExp.InvoiceNum = TranGLC.Key2
and APInvExp.InvExpSeq = TranGLC.Key4
and ( TranGLC.RelatedToFile = 'APinvExp' and TranGLC.RecordType = 'R' )
left outer join Erp.GLAcctDisp as GLAcctDisp on
TranGLC.Company = GLAcctDisp.Company
and TranGLC.COACode = GLAcctDisp.COACode
and TranGLC.GLAccount = GLAcctDisp.GLAccount
inner join Erp.Vendor as Vendor on
APInvDtl.Company = Vendor.Company
and APInvDtl.VendorNum = Vendor.VendorNum
left outer join Erp.PurTerms as PurTerms on
APInvHed.Company = PurTerms.Company
and APInvHed.TermsCode = PurTerms.TermsCode
left outer join Erp.SalesTer as SalesTer on
APInvHed.Company = SalesTer.Company
and APInvHed.sgcTerritoryID_c = SalesTer.TerritoryID
where (APInvHed.Posted = True)
Since our upgrade to 10.2.300, Bad SQL statement that is all we get usually… The error will be fully detailed in the event viewer on your Epicor server…
Post NOTE:
the result sets are NOT the same - although the Inner join provides 4 more entries. (1986 v 1990) GL accounts must have a display record, so i am not thinking it’s not a problem. But i will do some more testing and provide update if needed.
OK - Here is the skinny. Error due to execution timeout
The inner join had the effect of reducing the execution time.
When i change the BAQ execution setting ‘query timeout’ to 40000000
the inner join and the original query (with fields)
(a) provide the SAME number of records and
(b) complete without ERROR
during testing i noticed error conditions around when over 30000 ns of execution time. and although I THOUGHT i had changed the ‘query timeout’
i suppose the number - it wasn’t big enough.
which also explains WHY the sometimes when i removed some of the non-essential tables the results were error free.
it just so happened the GLACCTDISP was the last table -
and the straw that broke the camels back.
i suppose if i had ready access to the event viewer it would have been quickly apparent … but i don’t.
So problem solved and mystery solved
Thanks again to you Brandon and Pierre
and to this forum!
