Aaron,
Thanks for the help. Your suggestion work with one change, I had to use OldJobOper.Number01 instead of Old.JobOper.Number01.
Thanks again.
Rich Wagner
[cid:image001.jpg@01CA3785.8AC16A70]
412-384-3100
rwagner@...<mailto:rwagner@...>
www.bawplastics.com<http://www.bawplastics.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Aaron Hoyt
Sent: Thursday, September 17, 2009 9:29 AM
Subject: Re: [Vantage] BAM Alert
Rich,
Use the Old.Table.Field format to compare (in your case
Old.JobOper.Number01>0).
You will have to execute this through a .p file, but there is a ton of
history in this very list about .p files and BAMs (not an insignificant
portion directly from me).
I don't work much with .p files anymore, but I still am writing progress
code in BPMs in 8.x, so I can offer more assistance if needed.
Aaron Hoyt
RICH WAGNER wrote:
Thanks again.
Rich Wagner
412-384-3100
Rich,
Aaron Hoyt
> We are on 6.1 so a BPM is not an option right now. Do you mean I would
> write the old value to JobOper.Number02 and the new value would be in
> JobOper.Number01?
> Thanks,
> Rich Wagner
> 412-384-3100
> rwagner@...<mailto:rwagner%40bawplastics.com>
> <mailto:rwagner%40bawplastics.com><mailto:rwagner@...<mailto:rwagner%40bawplastics.com>
> <mailto:rwagner%40bawplastics.com>>
> <http://www.bawplastics.com/>>
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On
> Behalf Of Steven Gotschall
> Sent: Thursday, September 17, 2009 8:50 AM
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> You could do this with a BPM, but with a BAM I think you are going to
> have to have two BAMS. One would execute a .p procedure that would set
> JobOper.Number02 = JobOper.Number01 whenever Number01 changes. The
> other one would have to execute first and would send the email when
> JobOper.Number01 changes and JobOper.Number02 <> 0. The order here
> would be very important. I haven't tried it, but it should work.
> From: RICH WAGNER <rwagner@...<mailto:rwagner%40bawplastics.com>
> <mailto:rwagner%40bawplastics.com><mailto:rwagner%40bawplastics.com>>
> To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>"
> <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>>
> Sent: Thursday, September 17, 2009 8:25:46 AM
> Subject: [Vantage] BAM Alert
> I am trying to setup a BAM to send an email when a change occurs to
> the JobOper.Number01 field, but I only want to send the email when the
> original value was something other than 0.
> Is this even possible?
> Thanks,
> Rich Wagner
> [cid:image002.jpg@ 01CA3770. 74A86BE0]
> 412-384-3100
> rwagner@bawplastics .com<mailto:rwagner@bawplastics .com>
> www.bawplastics. com<http://www.bawplastics.com/
