BAM triggered when there is no change to field
Hi All,
I am trying to setup two BAMs, both against the OrderHed table, that
will be used to auto print a Sales Order Acknowledgement and a Sales
Order Confirmation, respectively.
The first BAM is only monitoring the field CheckBox05. It has a rule of
CheckBox05 = true. This BAM triggers the auto print successfully every
time. This is the BAM to print the Sales Order Acknowledgement.
My second BAM is monitoring ShortChar04. It has a rule of ShortChar04 <>
ShortChar06. I'm using this rule to prevent the BAM from running when
ShortChar04 is null. This is the BAM to print the Sales Order
Confirmation.
This BAM runs fine if I change ShortChar04 but it also runs every time
the first BAM runs, regardless if ShortChar04 changes or not.
Any ideas as to why the BAM for ShortChar04 is triggered even if the
value did not change?
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
