BAM with popup message
Just an alert message.
--- In vantage@yahoogroups.com, "brychanwilliams" <brychanw@h...>
wrote:
> Hi,
> Just want to check something, this doesn't actually stop the record
> being written does it? Just provides a warning?
> Thanks
> --- In vantage@yahoogroups.com, "progress92000" <nvong@m...> wrote:
> > Thanks Scott,
> > I got it finally. You are right.
> > I removed all other lines except
> > MESSAGE "Are you sure?" VIEW-AS ALERT-BOX TITLE "Alert Message".
> > In the BAM I selected Part table and Inactive field. So whenever
I
> > change the inactive check box the message will pop-up immediately.
> > Nam
> > --- In vantage@yahoogroups.com, "Lepley, Scott A." <sal@m...>
> wrote:
> > > Nam,
> > > I'm usually not inclined to contradict what Support has told
> > someone, but if
> > > you were truly told this, you were mislead. We are using BAM
> here
> > to
> > > generate pop-up alerts/warnings under several different
> scenarios.
> > If the
> > > alerts are coded properly (my challenge), they are triggered
when
> > > appropriate.
> > > Regards,
> > > Scott Lepley
> > > Systems Administrator
> > > Mauell Corporation
> > > Phone: 717-432-8686, ext. 14
> > > Fax: 717-432-8688
> > > Email: sal@m...
> > > Vantage version: 6.10.526
> > > -----Original Message-----
> > > From: progress92000 [mailto:nvong@m...]
> > > Sent: Monday, June 20, 2005 7:38 AM
> > > To: vantage@yahoogroups.com
> > > Subject: [Vantage] Re: BAM with popup message
> > > Epicor technical support confirm that there is no way to create
> a
> > pop-
> > > up warning in BAM in version 6.1. The option is abailable in
> > version
> > > 8.0
> > > Thank you all,
> > > Nam
> > > --- In vantage@yahoogroups.com, "Calvin Dekker" <calvin@m...>
> wrote:
> > > > Mark -
> > > > Is the BAM Process Server running? Simply starting the
Process
> > > > Server doesn't automatically start the BAM Process Server.
> Also,
> > > > did you save the file in the mfgsys/ud folder?
> > > > Calvin
> > > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]
> On
> > > Behalf
> > > > Of macolson10a
> > > > Sent: Saturday, June 18, 2005 11:31 AM
> > > > I'm not having any luck with the BAM program either. I have a
> > > > simple pop-up message program that works fine from Vantage
> Basic
> > > > EditProg, but when I try it as a BAM program it does not work
> > (never
> > > > tried this before).
> > > > I'm sure Epicor is running the BAMs with the NO-ERROR
> parameter so
> > > > whatever the error is we won't know. It may be something as
> > simple
> > > > as what folder the program is in. I'm going to keep testing
> > because
> > > > now I must know.
> > > > Mark Olson
> > > > TEAM Industries
> > > > 763-691-2381
> > wrote:
> > > > > Put a period at the end of your commands. SYNTAX SYNTAX
> SYNTAX
> > > > > {ud/GlbAlert.i &TableName = "Part"}
> > > > > IF Mfgsys.Part.Inactive = TRUE THEN DO:
> > > > Message".
> > > > > END.
> > > > > HTH,
> > > > > Calvin
> [mailto:vantage@yahoogroups.com]On
> > > > Behalf
> > > > > Of progress92000
> > > > > Sent: Friday, June 17, 2005 2:16 PM
> > > > > In the BAM I selected Part table with fields Partnum,
> Inactive
> > > > > And it is an alert program.
> > > > > --- In vantage@yahoogroups.com, "macolson10a"
<macolson@n...>
> > > > wrote:
> > > > > > What did you do to get a record into the 'Part' record
> buffer
> > or
> > > > > > where are you running this code?
> <nvong@m...>
> > > > wrote:
> > > > > > > I did try the following code but had no pop-up message.
> What
> > > > did
> > > > > i
> > > > > > do
> > > > > > > wrong? Thanks
> > > > > > > THEN DO:
> > > > > > > MESSAGE STRING("Are you sure?") VIEW-AS ALERT-BOX
> > > > > > > QUESTION BUTTONS YES-NO TITLE "Alert
> Message"
> > > > > > > END
> > > > > > > --- In vantage@yahoogroups.com, pjw@s... wrote:
> > > > > > > > Note, missing " after word 'message.'
> > > > > > > > Patrick Winter
> > > > > > On
> > > > > > > Behalf Of
> > > > > > > > progress92000
> > > > > > > > Sent: Wednesday, May 11, 2005 11:18 AM
> > > > > > > > Thanks,
> > > > > > > > I tried but the message just flash. I will try again.
> > > > > > > > > MESSAGE STRING("Hey here is a message.) SKIP
> > > > > > > > > STRING("More Stuff")SKIP
> > > > > > > > > VIEW-AS ALERT-BOX INFO
> > > > > > > > > TITLE "This is my message box for Job " +
> > JobNum.
> > > > > > > > > RETURN
> > > > > > > > > Patrick Winter
> > > > > > On
> > > > > > > > Behalf Of
> > > > > > > > > progress92000
> > > > > > > > > Sent: Thursday, May 05, 2005 7:00 AM
> > > > > > > > > Subject: [Vantage] BAM with popup message
> > > > > > > > > Can anyone suggestion some codes to popup message
on
> the
> > > > > > screen?
> > > > > > > > > Thanks,
Can anyone suggestion some codes to popup message on the screen?
TITLE "This is my message box for Job " + JobNum.
RETURN
Patrick Winter
progress92000
Yahoo! Groups Links
Here's another...
message "The job just released does not have a scheduled finish date. The
job scheduling function should be run for this job." VIEW-AS ALERT-BOX
warning buttons ok.
Regards,
Scott Lepley
Mauell Corporation
Fax: 717-432-8688
Email: sal@...
Vantage version: 6.10.524
Sent: Thursday, May 05, 2005 8:13 AM
Subject: RE: [Vantage] BAM with popup message
RETURN
Patrick Winter
progress92000
> RETURN
> Patrick Winter
Behalf Of
> progress92000
> Thanks,
must have
Builder and
> Yahoo! Groups Links
Patrick Winter
progress92000
> RETURN
> Patrick Winter
Behalf Of
> progress92000
> Thanks,
must have
Builder and
> Yahoo! Groups Links
Yahoo! Groups Links
I did try the following code but had no pop-up message. What did i do
wrong? Thanks
THEN DO:
QUESTION BUTTONS YES-NO TITLE "Alert Message"
END
> Patrick Winter
Behalf Of
> progress92000
> Thanks,
> > RETURN
> > Patrick Winter
> Behalf Of
> > progress92000
> > Thanks,
> must have
access. )
> Builder and
> > Yahoo! Groups Links
must have
Builder and
> Yahoo! Groups Links
What did you do to get a record into the 'Part' record buffer or
do
> wrong? Thanks
> THEN DO:
> END
> > Patrick Winter
On
> Behalf Of
> > progress92000
> > Thanks,
> > > RETURN
> > > Patrick Winter
On
> > Behalf Of
> > > progress92000
screen?
> > > Thanks,
You
> > must have
> access. )
> > Builder and
goto:
> > > Yahoo! Groups Links
You
> must have
access. )
> Builder and
> > Yahoo! Groups Links
In the BAM I selected Part table with fields Partnum, Inactive
i
> do
> > wrong? Thanks
> > THEN DO:
> > END
> > > Patrick Winter
> On
> > Behalf Of
> > > progress92000
> > > Thanks,
> > > > RETURN
> > > > Patrick Winter
> On
> > > Behalf Of
> > > > progress92000
> screen?
> > > > Thanks,
> You
> > > must have
> > access. )
> > > Builder and
> goto:
> > > > Yahoo! Groups Links
> You
> > must have
> access. )
> > Builder and
> > > Yahoo! Groups Links
Put a period at the end of your commands. SYNTAX SYNTAX SYNTAX
END.
HTH,
Calvin
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of progress92000
i
> do
> > wrong? Thanks
> > THEN DO:
> > END
> > > Patrick Winter
> On
> > Behalf Of
> > > progress92000
> > > Thanks,
> > > > RETURN
> > > > Patrick Winter
> On
> > > Behalf Of
> > > > progress92000
> screen?
> > > > Thanks,
> You
> > > must have
> > access. )
> > > Builder and
> goto:
> > > > Yahoo! Groups Links
> You
> > must have
> access. )
> > Builder and
> > > Yahoo! Groups Links
Yahoo! Groups Links
simple pop-up message program that works fine from Vantage Basic
EditProg, but when I try it as a BAM program it does not work (never
tried this before).
I'm sure Epicor is running the BAMs with the NO-ERROR parameter so
whatever the error is we won't know. It may be something as simple
as what folder the program is in. I'm going to keep testing because
now I must know.
Mark Olson
TEAM Industries
763-691-2381
Message".
> END.
> HTH,
> Calvin
Behalf
> Of progress92000
did
> i
> > do
> > > wrong? Thanks
> > > THEN DO:
> > > END
> > > > Patrick Winter
> > On
> > > Behalf Of
> > > > progress92000
> > > > Thanks,
> > > > > RETURN
> > > > > Patrick Winter
> > On
> > > > Behalf Of
> > > > > progress92000
> > screen?
> > > > > Thanks,
Note:
> > You
> > > > must have
> > > access. )
Report
> > > > Builder and
> > goto:
> > > > > Yahoo! Groups Links
> > You
> > > must have
> > access. )
> > > Builder and
goto:
> > > > Yahoo! Groups Links
must have
Builder and
> Yahoo! Groups Links
Mark -
Is the BAM Process Server running? Simply starting the Process
Server doesn't automatically start the BAM Process Server. Also,
Calvin
Of macolson10a
tried this before).
now I must know.
Mark Olson
TEAM Industries
763-691-2381
Message".
> END.
> HTH,
> Calvin
Behalf
> Of progress92000
did
> i
> > do
> > > wrong? Thanks
> > > THEN DO:
> > > END
> > > > Patrick Winter
> > On
> > > Behalf Of
> > > > progress92000
> > > > Thanks,
> > > > > RETURN
> > > > > Patrick Winter
> > On
> > > > Behalf Of
> > > > > progress92000
> > screen?
> > > > > Thanks,
Note:
> > You
> > > > must have
> > > access. )
Report
> > > > Builder and
> > goto:
> > > > > Yahoo! Groups Links
> > You
> > > must have
> > access. )
> > > Builder and
goto:
> > > > Yahoo! Groups Links
must have
Builder and
> Yahoo! Groups Links
Yahoo! Groups Links
Epicor technical support confirm that there is no way to create a pop-
up warning in BAM in version 6.1. The option is abailable in version
8.0
Thank you all,
Nam
> Mark -
> Calvin
Behalf
> Of macolson10a
> tried this before).
> now I must know.
> Mark Olson
> TEAM Industries
> 763-691-2381
> Message".
> > END.
> > HTH,
> > Calvin
> Behalf
> > Of progress92000
> did
> > i
> > > do
> > > > wrong? Thanks
> > > > THEN DO:
> > > > END
> > > > > Patrick Winter
> > > On
> > > > Behalf Of
> > > > > progress92000
> > > > > Thanks,
> > > > > > RETURN
> > > > > > Patrick Winter
> > > On
> > > > > Behalf Of
> > > > > > progress92000
> > > screen?
> > > > > > Thanks,
> Note:
> > > You
> > > > > must have
> > > > access. )
> Report
> > > > > Builder and
> > > goto:
> > > > > > Yahoo! Groups Links
> > > You
> > > > must have
> > > access. )
Report
> > > > Builder and
> goto:
> > > > > Yahoo! Groups Links
> must have
access. )
> Builder and
> > Yahoo! Groups Links
must have
Builder and
> Yahoo! Groups Links
Nam,
I'm usually not inclined to contradict what Support has told someone, but if
you were truly told this, you were mislead. We are using BAM here to
generate pop-up alerts/warnings under several different scenarios. If the
alerts are coded properly (my challenge), they are triggered when
appropriate.
Regards,
Scott Lepley
Mauell Corporation
Fax: 717-432-8688
Email: sal@...
8.0
Thank you all,
Nam
> Mark -
> Calvin
Behalf
> Of macolson10a
> tried this before).
> now I must know.
> Mark Olson
> TEAM Industries
> 763-691-2381
> Message".
> > END.
> > HTH,
> > Calvin
> Behalf
> > Of progress92000
> did
> > i
> > > do
> > > > wrong? Thanks
> > > > THEN DO:
> > > > END
> > > > > Patrick Winter
> > > On
> > > > Behalf Of
> > > > > progress92000
> > > > > Thanks,
> > > > > > RETURN
> > > > > > Patrick Winter
> > > On
> > > > > Behalf Of
> > > > > > progress92000
> > > screen?
> > > > > > Thanks,
Besides you could use the "net send" command to pop a message to the
"current logged in user".
Just a thought to take the complexity out of it.
I use this to notify purchasing that they have a Requisition available, but
it could be used locally as well.
If you would like details let me know.
Aaron Hoyt
Vantage Plastics
Of Lepley, Scott A.
Sent: Monday, June 20, 2005 8:29 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Re: BAM with popup message
Nam,
appropriate.
Regards,
Scott Lepley
Mauell Corporation
Fax: 717-432-8688
Email: sal@...
8.0
Thank you all,
Nam
> Mark -
> Calvin
Behalf
> Of macolson10a
> tried this before).
> now I must know.
> Mark Olson
> TEAM Industries
> 763-691-2381
> Message".
> > END.
> > HTH,
> > Calvin
> Behalf
> > Of progress92000
> did
> > i
> > > do
> > > > wrong? Thanks
> > > > THEN DO:
> > > > END
> > > > > Patrick Winter
> > > On
> > > > Behalf Of
> > > > > progress92000
> > > > > Thanks,
> > > > > > RETURN
> > > > > > Patrick Winter
> > > On
> > > > > Behalf Of
> > > > > > progress92000
> > > screen?
> > > > > > Thanks,
Yahoo! Groups Links
Thanks Scott,
In the BAM I selected Part table and Inactive field. So whenever I
Nam
--- In vantage@yahoogroups.com, "Lepley, Scott A." <sal@m...> wrote:
> Nam,
someone, but if
to
If the
> appropriate.
> Regards,
> Scott Lepley
> Mauell Corporation
> Fax: 717-432-8688
> Email: sal@m...
pop-
version
> 8.0
> Thank you all,
> Nam
> > Mark -
> > Calvin
> Behalf
> > Of macolson10a
(never
> > tried this before).
simple
because
> > now I must know.
> > Mark Olson
> > TEAM Industries
> > 763-691-2381
> > Message".
> > > END.
> > > HTH,
> > > Calvin
> > Behalf
> > > Of progress92000
or
> > did
> > > i
> > > > do
> > > > > wrong? Thanks
> > > > > THEN DO:
> > > > > END
> > > > > > Patrick Winter
> > > > On
> > > > > Behalf Of
> > > > > > progress92000
> > > > > > Thanks,
JobNum.
> > > > > > > RETURN
> > > > > > > Patrick Winter
> > > > On
> > > > > > Behalf Of
> > > > > > > progress92000
> > > > screen?
> > > > > > > Thanks,
Hi,
> Thanks Scott,
> Nam
wrote:
> > Nam,
> someone, but if
here
> to
scenarios.
> If the
> > appropriate.
> > Regards,
> > Scott Lepley
> > Mauell Corporation
> > Fax: 717-432-8688
> > Email: sal@m...
a
> pop-
> version
> > 8.0
> > Thank you all,
> > Nam
wrote:
> > > Mark -
Also,
> > > Calvin
On
> > Behalf
> > > Of macolson10a
Basic
> (never
> > > tried this before).
parameter so
> simple
> because
> > > now I must know.
> > > Mark Olson
> > > TEAM Industries
> > > 763-691-2381
SYNTAX
> > > Message".
> > > > END.
> > > > HTH,
> > > > Calvin
> > > Behalf
> > > > Of progress92000
Inactive
buffer
> or
<nvong@m...>
What
> > > did
> > > > i
> > > > > do
> > > > > > wrong? Thanks
> > > > > > THEN DO:
Message"
> > > > > > END
> > > > > > > Patrick Winter
> > > > > On
> > > > > > Behalf Of
> > > > > > > progress92000
> > > > > > > Thanks,
> JobNum.
> > > > > > > > RETURN
> > > > > > > > Patrick Winter
> > > > > On
> > > > > > > Behalf Of
> > > > > > > > progress92000
the
> > > > > screen?
> > > > > > > > Thanks,
