I don't believe that will work. I usually just setup a counter aggregate it
all manually in these kind of situations.
DEFINE VARIABLE total AS DECIMAL.
FOR EACH ttTable WHERE ttTable.Field = 1:
total = total + ttTable.Field.
END.
Or something similar.
END.
On Mon, Jun 4, 2012 at 4:36 PM, Winter, Patrick <pjw@...>wrote:
> All,
> Total(expression)
> Calculates the total of all the values of the numeric database field.
> Calculated field call 'May' set to decimal.
> Total(If Month(Add-interval( PartTran.TranDate , -1, 'month')) = 5
> Then PartTran.TranQty else 0)
> Check Syntax = OK
> My logic looks good for the test but if I setup for different months
> they all just give grand totals.
> So am I correct in assuming that you can't nest an 'if' statement in the
> TOTAL aggregate command.
> Anyone go down this road before.
> Seemed logical to me.
> Patrick Winter
*John Driggers*
*High End Dev, System Design, Profit Drinking*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
