Wonder if anyone has any ideas how to query BPMs for email addresses for a specific domain?
My first thought was to BpDirective.Body but… when I tried to use MATCHES .mydomain.com
I receive an error “Argument data type xml is invalid for argument 1 of like function”.
Ref screenshot of BAQ and error
If possible, I’d like a simple list of BPM Groups/Names that have email addresses specified.
Just to make it easier to find them when needed. (In this case a domain name is changing soon).
Try making a calc field of type varchar, with the expression convert(varchar, BpDirective.Body)
Then use a Sub query criteria to check the calc field.
I’m not sayin that this will work, it’s just the first thing I’d try.
edit
the above doesn’t work. But the following does:
cast(BpDirective.Body as nvarchar(max))
or skip making a varchar to hold that and directly test it (and using a bit filed to hold the result) with: (case when charindex(@Param1,cast(BpDirective.Body as nvarchar(max))) = 0 then 0 else 1 end)
Then add that calculated bit field to a sub query criteria:
