One of our companies that recently went live with Kinetic Cloud (from P21 on-prem) has a spreadsheet that has multiple data sources via connections to the on-prem P21 database. Since we’re cloud, I had them create BAQs with the data they need, and set up an Access Scope / API Key so they could use replace the old P21 Queries with BAQs. With some help from @Camren360’s posts to help me out, I was able to get that going without much headache.
Here’s my issue now: We have our users authenticating in Epicor with Epicor Identity (IDP). I don’t let them use Basic authentication. But in order to refresh the connections in the Excel sheets, they need to add a ‘Basic’ username and password in order to access the BAQ.
My options as I see them:
Let them maintain a ‘basic’ username and password. I don’t like this, because they’ll just use this and skip the Identity login (and the MFA that comes with it).
Create a service account that all users could use to authenticate on the BAQ API calls. This would require me to give out a username and password to several people. I don’t like that either. I already created this user, and set access to “Disallow” on basically every Menu Security, but I’m not sure if sharing that around will have any other security risks.
Is there a better option that I missed? Or is there a way to potentially eliminate the issues with the options above?
There is examples and code in the Epicor IdP help to setup Excel as an app for authentication. Although not tried it I know it is there and may be worth a review.
Alternatively create secondary accounts for those needing to use the excel sheets and on that account setup as basic and apply an access scope that gives access to only a select few BAQs?
Same title but different article it looks like. The one in the Epicor IDP docs was updated in January. And it lives under Epicor Management > Identity Provider Administration.
If you go to Log In - Epicor Identity and click the ? in the top right. Then search for Excel see if you can find the article. It has the code examples mentioned by @BenWheeldon
