Brian,
Give this a try...
IF OrderRel.Date01 > 01/01/1999
THEN OrderRel.Date01
ELSE OrderDtl.Date01
NB
--- In vantage@yahoogroups.com, "Brian W. Spolarich "
<bspolarich@...> wrote:
Give this a try...
NB
>info
> Vantage 8.03.405/SQL.
> I want to add a calculated field to a query on SalesOrder release
> that returns OrderRel.Date01 if it is not null, and OrderDtl.Date01if
> it is:result
> FieldName: CalcCustReqBy
> Expression:
> if OrderRel.Date01 = ?
> then OrderDtl.Date01
> else OrderRel.Date01
> Format: (blank)
> Data Type: DateTime
> If I Test the BAQ with this field and expression I get an empty
> set. If I remove it, or set the expression tojust "OrderDtl.Date01"
> for example, it returns what I expect.Photonix /
> The MfgSys803.server.log file shows this error when I run the BAQ:
> [08/12/16@15:35:50.231-0500] P-009408 T-010072 1 AS -- (Procedure:
> 'runSQLQuery bo/DynamicQuery.p' Line:44587) 37000: [Microsoft][SQL
> Native Client][SQL Server]Incorrect syntax near the keyword 'from'.
> Native Client][SQL Server]Incorrect syntax near 'Customer'.
> What's the deal?
> -bws
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced
> Picometrix
> bspolarich@...
> <mailto:bspolarich@...> ~ 734-864-5618 ~
> www.advancedphotonix.com <http://www.advancedphotonix.com>
