I am making a BAQ and have hit a problem wall. I am trying to create a column that shows me all the JobNums that end in “-1-1”. So for example, a job might be 1089628-1-1. I want to see ALL of them. But we have jobs that don’t have that suffix, so I want to avoid seeing those.
Additionally, for the second portion, I want to also see jobs that start with the letter ‘C’.
So one column shows me “-1-1” jobs and the other column shows me jobs that start with ‘C’ like C67981.
Any help would be appreciated. AI is not being very helpful.
What do you mean by creating two columns with job numbers? Are you trying to aggregate all these job numbers into a single row? What’s the actual goal?
There other way to do this if it’s just a filter you are after is:
I’d be inclined to add two parameters
Starting with and Ending with
Then put a criteria on the job number (twice) one for each parameter using a begins operation for the starting with and a contains for the ending with.
Try to limit likes as they can be a bit of a performance dog. Not sure if contains and starting are any better to be honest.
