BAQ Case Statement
Thanks Linda that was my problem.
~Charlie
_____
Linda Lowney
Sent: Tuesday, January 05, 2010 8:08 AM
Subject: RE: [Vantage] BAQ Case Statement
Hi Charlie,
Try:
if 0 < 1 then "3" else ""
It seems to expect the ELSE.
Regards,
Linda
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Charlie Wilson
Sent: Tuesday, January 05, 2010 7:57 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
I keep getting syntax errors so I tried
If 0 < 1 then
"3"
And this too gave me a syntax error I stuck an end if on there and that
gave
me a syntax error as well.
~Charlie
_____
<mailto:vantage%40yahoogroups.com> ] On
Behalf Of
Karen Schoenung
Sent: Monday, January 04, 2010 2:10 PM
Charlie,
I think you are pretty close...
If (NonConf.systime / 3600 >= 0 and nonconf.systime / 3600 < 8) then
"Shift 3"
if (NonConf.systime / 3600 >= 8 and nonconf.systime / 3600 < 16) then
"Shift 1"
Else
"Shift 2"
I would try the first if in a calc field, analyze and test...Then add
the second if in the same calc field, analyze and test, so on...
Karen
Behalf
Of Charlie Wilson
Sent: Monday, January 04, 2010 12:39 PM
Subject: [Vantage] BAQ Case Statement
All,
I am attempting to set up a calculated field in a BAQ I need to use
either
an If / Else if statement or a case statement that does the following:
If NonConf.systime / 3600 >= 0 and nonconf.systime / 3600 < 8 then
Print Shift 3
Else if NonConf.systime / 3600 >= 8 and nonconf.systime / 3600 < 16 then
Print Shift 1
Else
Print Shift 2
End If
I've never done an if else statement in this can anyone show me what I
should put in?
If it just kicks out a 1, 2 or 3 that is fine.
~Charlie
All,
I am attempting to set up a calculated field in a BAQ I need to use either
Print Shift 3
Print Shift 1
Else
Print Shift 2
End If
should put in?
~Charlie
Charlie,
"Shift 3"
"Shift 1"
Else
"Shift 2"
Karen
Of Charlie Wilson
All,
either
Print Shift 3
Print Shift 1
Else
Print Shift 2
End If
should put in?
~Charlie
If 0 < 1 then
"3"
And this too gave me a syntax error I stuck an end if on there and that gave
~Charlie
_____
Karen Schoenung
Charlie,
"Shift 3"
"Shift 1"
Else
"Shift 2"
Karen
Behalf
Of Charlie Wilson
All,
either
Print Shift 3
Print Shift 1
Else
Print Shift 2
End If
should put in?
~Charlie
Hi Charlie,
Try:
Regards,
Linda
Of Charlie Wilson
If 0 < 1 then
"3"
gave
~Charlie
_____
Behalf Of
Karen Schoenung
Charlie,
"Shift 3"
"Shift 1"
Else
"Shift 2"
Karen
Behalf
Of Charlie Wilson
All,
either
Print Shift 3
Print Shift 1
Else
Print Shift 2
End If
should put in?
~Charlie
Hi Charlie,
I have found that if you use a set of parenthises in a nested IF statement that this usually solves the problem. Try this:
"Shift 3"
Else (If (NonConf.systime / 3600 >= 8 and nonconf.systime / 3600 < 16) then
"Shift 1"
Else
"Shift 2")
David Pfiester
NuStep, Inc.
734-769-3939 x150
> If 0 < 1 then
> "3"
> ~Charlie
> _____
> Karen Schoenung
> Charlie,
> "Shift 3"
> "Shift 1"
> Else
> "Shift 2"
> Karen
> Behalf
> Of Charlie Wilson
> All,
> either
> Print Shift 3
> Print Shift 1
> Else
> Print Shift 2
> End If
> should put in?
> ~Charlie
