I can’t find the BAQ comboBox in the object explorer. I am trying to see if there is a method that resets it. I currently want to run the BAQ when the arrow is clicked. This works the first time. The BAQ fires and the variable window appears. what I want is that once my custom methods have run that I can reset the combobox to fire again when the arrow is clicked. Does anyone have any insight on what methods there are for a BAQ combobox? Do I need to remove the control and programatically add it back each time?
Look at the bottom of the list under Controls. There you will find EpiCombo. There is a Refresh method that may work. You could also try this bit of code that refreshes the entire dashboard and all queries.
void RefreshAllBAQs()
oTrans.PushStatusText("Refreshing all views. Please be patient...", false);
MainController.AppControlPanel.HandleToolClick("RefreshAllTool", new
Infragistics.Win.UltraWinToolbars.ToolClickEventArgs(MainController.MainToolManager.Tools["RefreshAllTool"], null));
oTrans.PushStatusText("Done!", false);
