Is it possible to have a criteria in a BAQ that is only evaluating a Parameter value, and doesn’t consider the value of any table/calculated field?
For example, if I have a boolean parameter, and I want to use it as a way to control my WHERE clause, so that it is only evaluated if that boolean parameter is true, can I do that in a BAQ?
In a SQL query I would write something like this:
DECLARE @AnyPart bit
DECLARE @PartNum nvarchar(50)
SELECT * FROM erp.Part
WHERE @AnyPart = 1 OR Part.PartNum = @PartNum
I don’t know of a way to make the WHERE @AnyPart = 1 part of the query in a BAQ.
