I copied a system BAQ from the zHOMEPAGE series and modified the columns and sort order to get the output I needed. This is working and now I want to make it a cross company query however this setting is greyed out/not settable.
I have created BAQ’s from scratch as cross company queries before. Short of recreating this query from scratch, what else can I try to get this working cross companies?
Is that a setting that could be tweaked in the XML of an export?
Solved. I was running this BAQ in a Pilot system in order to see our data rather than Epicor test data however it turns out that this system is not configured for cross company.
I’ve exported the query, imported it into the demo system and now have access to the cross company setting.
