If it was a snake it would have bit me!
~Charlie
_____
Karen Schoenung
Sent: Wednesday, June 24, 2009 12:35 PM
Subject: RE: [Vantage] BAQ Crystal Report Problem
Charlie,
In Crystal Reports, you have the option under File...Save or Save with
report data...
Karen
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Charlie Wilson
Sent: Wednesday, June 24, 2009 11:32 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
How do you save the report without data in it?
~Charlie
_____
<mailto:vantage%40yahoogroups.com> ] On
Behalf Of
Rob Bucek
Sent: Wednesday, June 24, 2009 12:27 PM
You said that right Charlie, its probably by sheer luck then that it
hasn't happened to me as it is force of habit to not save data in the
reports... it would have had me stumped, and I run reports remotely
quite often.
Behalf
Of Charlie Wilson
Sent: Wednesday, June 24, 2009 8:38 AM
I got it straitened out the first response was right it was pulling the
data
saved in the report when I opened it locally. But when I went somewhere
else
it tried to find a new dataset that wasn't in the same local. Also the
dataset I used to design the report wasn't right. The "sample data" I
used I
pulled from a dashboard I had to pull another set of sample data from
the
BAQ itself and redo the majority of the report all is working now.
This is the first BAQ to crystal I have done so I'm figuring it out as I
go.
Not the smoothest process in the world to do. Lots of places you can get
hung up.
~Charlie
_____
Behalf Of
Rob Bucek
Sent: Wednesday, June 24, 2009 9:23 AM
Charlie, did you create that BAQ report while remoted into the server?
Behalf
Of Charlie Wilson
Sent: Wednesday, June 24, 2009 7:56 AM
I'm on 8.03.407.
Epricor has them all over the place. Quotes, invoices, AP checks, and
several other places. It's going on in the background. Instead of the
Crystal opening a ODBC into the DB for it's data vantage kicks out a
....XML
file that is then read by the crystal report.
~Charlie
_____
Behalf Of
Patty Richter
Sent: Wednesday, June 24, 2009 8:44 AM
Subject: Re: [Vantage] BAQ Crystal Report Problem
'canned' BAQ to crystal reports??? This caught my interest - what
version
are you on? and what do you mean by 'canned'...
From: Charlie Wilson <foamdesigncsw@ <mailto:foamdesigncsw%40yahoo.com>
yahoo.com>
Sent: Wednesday, June 24, 2009 6:11:01 AM
Subject: [Vantage] BAQ Crystal Report Problem
All,
I have created a nice little report for our QA department that prints up
to
nice Corrective actions forms. But I have a problem when I run the
report
when I am remoted into the server it works perfectly but if I run it
from
any other machine it ask me to specify the location of the dataset and
enter
a username and password. Now my guess would be that crystal is getting
passed the location of the dataset (.xml file) in this format
c:\epicor\mfgsysdat a\reports\ username\ ****.xml instead of like this
\\servername\ epicor\mfgsysdat a\reports\ username\ ****.xml. The only
problem
is I can't figure out where the setting is to adjust this. Any ideas?
PS all of the "canned" BAQ to Crystal reports are working for us just
not
this one I have made.
~Charlie
~Charlie
_____
Karen Schoenung
Charlie,
report data...
Karen
Behalf
Of Charlie Wilson
~Charlie
_____
Behalf Of
Rob Bucek
quite often.
Behalf
Of Charlie Wilson
data
else
used I
the
go.
hung up.
~Charlie
_____
Behalf Of
Rob Bucek
Behalf
Of Charlie Wilson
I'm on 8.03.407.
....XML
~Charlie
_____
Behalf Of
Patty Richter
version
yahoo.com>
All,
to
report
from
enter
problem
not
~Charlie
