From: "'Winter, Patrick' pjw@... [vantage]" <vantage@yahoogroups.com>
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Subject: [Vantage] BAQ DMR table link
Date: Tue, May 26, 2015 3:56 PM
I believe failing the inspection processing creates the NonConf record.
Sent: Tuesday, May 26, 2015 15:35
Subject: Re: [Vantage] BAQ DMR table link
I will try that...what if no Non-Conf has been created?
On Tuesday, May 26, 2015 3:33 PM, "'Winter, Patrick' pjw@... [vantage]" <vantage@yahoogroups.com> wrote:
Try linking the DMRHead to NonConf
Patrick Winter
Sent: Tuesday, May 26, 2015 14:26
To: Vantage List
I need to get the PO# associated with the DMR. You can see the PO # in the inspection processing but once failed it is lost in the DMR. What is table could I link to get the PO #? I have tried several and linking several ways. The DMRActnReject is not seen when creating a BAQ so I am not sure it is just a temp table.
thanks Kim
ÂÂ
ÂÂ
