hi
CurrentCompany is a Special BAQ Variable. I don't know much about your version but
if you change where the CurrentCompany field is being used - does the BAQ work?
You could hard code the company id - just for the test
Marianne
mgizzi@...
hi
Marianne
mgizzi@...
Have anyone seen this error before?
When I test the BAQ I get this:
Error Detail
4GL STOP condition: The Server application has returned an error. (7243) (7241)
Stack Trace
at Epicor.Mfg.UI.App.BusinessActivityQuery.BAQTransaction.Execute()
at Epicor.Mfg.UI.App.BusinessActivityQuery.BAQ.btnTest_Click(Object sender, EventArgs e)
Then this is in the Appserver Logs.
(Procedure: 'runSQLQuery bo/DynamicQuery.p' Line:44878) S0002: [Microsoft][SQL Server Native Client 10.0][SQL Server]Invalid object name 'dbo.CurrentCompany'.
There is no dbo.currentcompany in the database anywhere that I can see, any suggestions?
