Need to only extract the FIRST Labor Detail record within a BAQ
I have seen where SQL has MIN-date which would accomplish the task.
Already have a BAQ to pull LABOR-HEAD data for clock-in and clock-out, so I wanted to leverage that. Need to get the first job-activity and compare the clock-in to first reported activity transaction, but DO NOT NEED all the records (until my boss changes his mind one more time).
When he does change his mind… is there a way to get the first and the last labor detail record???
Reason - DOL (Dept of Labor) requested an audit of clock-in and out, against the shift-time (ie: employees are owed for the minutes they are early and leave late. We allow 3 mins late, but if 5 mins late, we record adjusted clck-in to the quarter hour. Employee clocks in at 8 mins after hour, time adj to :15… DOL says we owe them 7 mins!
We want to show composite total of delta.
