Baq field filtered on bit/checkbox open orders only
Beginner…
I’m attempting to filter OrderDtl_OpenLine to only pull records of orders that are open. This field is a checkbox. I’ve made several attempts to try different filter values to no avail. I either get Open AND Closed or I get nothing.
Hi Lori, can you show your screenshots of your BAQ phrase builder with the table criteria on the OrderDtl table? It probably has to do with your logic or your table join
Hi Lori, set criteria of OpenLine = True
That was so easy and I was making it difficult. Thank you afabian!
If you do eventually want to filter on a bit field, I’ve found you need to add a calculated field to transform the bit into a Yes/No string value. Then you can filter using that to include true, false or both fairly easily. Dashboards don’t really do bit filtering well directly.
I’m pretty sure it will work with OpenLine = 1 too. Or 0 for false
I was able to make it work, per Aeron’s post:
Go to Table Criteria > Select Field > Operation equals “=”, Filter Value / Constant = “True”
Thank you all for your responses. I’ve made notes of the other suggestions for future use.
