Hi all,
I can see that [JobHead].[TravelerLastPrinted] gives the last date when the Job traveler was printed by someone.
However, is it possible to see who printed it? is there a field that defines this?
Himal
Hi all,
Himal
I don’t believe there is by default, but you could create a UD field and a BPM to take care of that.
Another option could be to do a bpm to enable the change log and track changes on the last printed field.
Then in your BAQ you could a join to the change log based on Table name JobHead and LogText matches LastPrinted.
Done something similar here but for when a user either changes a shipment quantity or add lines to a shipment.
Hope this helps
