BAQ for Indirect Labor Costs in 9.05
Please ignore, figured it out.
--- In vantage@yahoogroups.com, "just_check" <justrichpower@...> wrote:
> I want to capture the indirect labor of employees that clock into specific indirect labor operations.
> Tech support suggested labordtl, but when I pull data from table, I get no data exists.
> Thanks
> Justin
Justin
LaborDtl is the correct table, filter for LaborType = 'I', and display
the IndirectCode.
Brian.
Of just_check
Sent: Wednesday, July 18, 2012 1:27 PM
Subject: [Vantage] BAQ for Indirect Labor Costs in 9.05
no data exists.
Justin
I'm running a version of a BAQ that support sent to verify labor entry status. The base table is LaborDtl and I am getting data back on it - even if labor is saved instead of submitted. I see the time even if the jobs aren't closed and COS/WIP Capture hasn't been run. Are you checking for LaborType=I? If you're joining to other tables you might want to use a Left Join to see if you can return data then.
