BAQ for Invoice Detail
Hi,
It is my mistake on the test, actually the BAQ is workingfine, just some mistake on the test data.
Problem solved.
Thanks.
--- In vantage@yahoogroups.com, "kw_foo" <kwfoo88@...> wrote:
> Do you mind to elaborate more on the running total with a condition formula?
> My BAQ as follow:
> Tables:
> InvcDtl
> InvcHead
> InvcMisc - aggregate enable
> MiscChrg - aggregate enable
> Links:
> InvcDtl - Inner Join with InvcHead (InvoiceNum)
> InvcDtl - Outer Join with InvcMisc (InvoiceNum & InvoiceLine)
> InvcMisc - Inner Join with MiscChrg (MiscCode)
> (tried to put in a filter in the MiscChrg table to include only SalesAnalysis = TRUE, but seem like not functioning, records in InvcMisc with MiscCode where SalesAnalysis still included in the TOTAL sum)
> Calculate Fields:
> MiscAmt - TOTAL(InvcMisc.MiscAmt)
> Please advice.
> --- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@> wrote:
> > Yes, you can use Running Totals with a conditional formula.
> > -bws
> > Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
> > Â Â Â Â bspolarich@ ~ 734-864-5618 ~ www.advancedphotonix.com
> > -----Original Message-----
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of kw_foo
> > Sent: Friday, October 16, 2009 8:08 AM
> > Subject: [Vantage] Re: BAQ for Invoice Detail
> > Hi,
> > I manage to find the solution on the Crystal report to add the Sum of a formula field to the chart for TopN purpose.
> > Later I notice another problem on the MiscAmt which I use the aggregate function TOTAL to add up all Misc Amount for the invoice line, but I need to EXCLUDE the MiscCode which is not for Sales Analysis (MiscChrg->SalesAnalysis = FALSE). Is there any aggregate function can do conditional sum ?
> > Please help.
> > --- In vantage@yahoogroups.com, "kw_foo" <kwfoo88@> wrote:
> > > Hi,
> > > I am trying to generate a BAQ which show the total amount of each invoice line, which include the Misc Amt for that line.
> > > I able to create a calculation field:
> > > ItemAmt -> (InvcDtl.OurShipQty * InvcDtl.UnitPrice - InvcDtl.Discount)
> > > Also
> > > MiscAmt -> TOTAL(InvcMisc.MiscAmt) as a seperate field in the BAQ.
> > > When I am trying to create another calc field:
> > > TotalInvAmt -> ItemAmt + MiscAmt
> > > The TotalInvAmt always return <empty> ?? Both the ItemAmt & MiscAmt have no problem.
> > > The main purpose is to pass this field to Crystal Report to generate a chart group by Product Group which use the "Sum of TotalInvAmt" as the TopN base.
> > > I also trying to work on Crystal Report to add as a formula field, but not sure how to make it appear under the TopN base selection.
> > > Please help.
> > > Thanks in advance.
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> > (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Hi,
Also
Please help.
Thanks in advance.
Hi,
Please help.
> Hi,
> Also
> Please help.
> Thanks in advance.
-bws
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
Hi,
Please help.
> Hi,
> Also
> Please help.
> Thanks in advance.
My BAQ as follow:
Tables:
InvcDtl
InvcHead
Links:
Calculate Fields:
Please advice.
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> -bws
> Â Â Â Â bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
> Hi,
> Please help.
> > Hi,
> > Also
> > Please help.
> > Thanks in advance.
