John,
BAQ within PO suggestions works fine. I just needed to get the key field correct to make it work. I set the BAQ as the default search when PO suggestions popped up and it works great. Additionally we are using the the filter on the grid to filter out records we do not want. I don't want to see records that are very small (.00000001) because that is how our engineers mark material that is not ready to be purchased at this time.
--- In vantage@yahoogroups.com, "mitchelljohn" <mitchelljohn@...> wrote:
> Joshua,
> You can use a BAQ within the PO suggestion screen? This would let us purchase just for our distribution center and not for our retail stores. Right now we are using Multi Plant, but I am trying to get rid of that simplify our system.
> --- In vantage@yahoogroups.com, "Joshua" <jgeske@> wrote:
> > John,
> > We are just reading the value. We did not need the SUGNUm for anything except to show the record.
> > I see two ways to purchase for a specific warehouse.
> > 1. Create a BAQ that limits what you see in PO suggestions to only that warehouse.
> > 2. Make sure the warehouse is showing on the po suggestions screen. (i think by default it is not so you will have to create a new BAQ) then use the filter function on the grid to filter out all other warehouses.
> > This would make me nervous if I had multiple warehouses and I was responsible for all of them because I would never see a suggestion for the other warehouses. This would include any mistakes that people made. For example maybe they setup the part in the wrong warehouse?
> > If your only responsible for one warehouse then I would use one of the two above.
> > Hope this helps..
> > --- In vantage@yahoogroups.com, "mitchelljohn" <mitchelljohn@> wrote:
> > > Joshua,
> > > Are you trying to input a SUGNUM value or just read it?
> > > We are a distributor (we do not manufacture anything) and we have multiple warehouses. We only purchase for one warehouse, but we are not able to create suggestions for that one warehouse, only for the plant. If we could create a SUGNUM value based off a BAM then we could only buy for a specific warehouse. Or is my logic deeply flawed?
> > > > John,
> > > > That worked!! I thought I had the SUGNUM in there but when I looked again it was not. Thanks!!
> > > > --- In vantage@yahoogroups.com, "upworth" <Upworth@> wrote:
> > > > > I was able to get a BAQ to show by using the SugPODtl table and selecting the SugNum field as a 'Like' column. I tried numerous other fields in this table, but the SugNum was the only one that would cause the BAQ to show.
> > > > > Hope this helps!
> > > > > Jonathan Tompkins
> > > > > Business Process Manager
> > > > > Alabama Specialty Products, Inc.
> > > > > > No luck. I cannot get any BAQ to show up in the Purchase Order Suggestion entry screen. Did you try to create a simple BAQ in your system to show up? We are testing on 9.05
> > > > > > --- In vantage@yahoogroups.com, "b_ordway" <cooner_55421@> wrote:
> > > > > > > The system checks the BAQ for key fields to decide it it will show up in a forms BAQ search.
> > > > > > > Try making a BAQ based on the PORel table that returns the PONum, POLin and PORelNum. That should show up.
> > > > > > > > I'm trying to create a BAQ that will show up in the Purchase Order Suggestions Entry screen when I click on the Binoculars to do a search.
> > > > > > > > For some reason no BAQ's will show up in this screen. Has anyone else seen this? To make sure I wasn't doing something wrong I created a simple BAQ for the Part screen. This showed up right away.
> > > > > > > > I checked to make sure the fields were added in the "Like" column on the BAQ query manager and everything looks fine.
> > > > > > > > Can someone else validate this is a bug/feature? Can anyone get any BAQ's to show up in the Purchase Order Suggestions Entry screen?
> > > > > > > > Any help would be very much appreciated.
> > > > > > > > Thanks
