BAQ from PartTrans table for finished goods
Thanks!  That's easy enough.  Using Crystal so it's a little easier.  Expect to have to do all these reports again when we upgrade to E10.
Hello,
I'm trying to pull all part transactions between 6/2013 to 12/2014 that are finished goods with these transaction types:
stock to job, stock to assembly, stock to customer, and job to stock.
I'd like to also display the quantity as of 12/2014 and last unit cost.
I'm struggling a bit getting the quantity as of 12/2014.
Thanks in advanced.
--SF
You'll want to filter on PartTran.TranType for STK-MTL, STK-ASM, STK-CUS, and MFG-STK. For the quantity, if this is for a report, I'd do a calculated field something like: if PartTran.TranDate >= Date("12/1/2014") then PartTran.TranQty else 0. Then you can sum up the calculated field in the report.
If I remember it's kind of tedious...
Accumulate the qty from the first PartTran record up to the cutoff date and accounting for all the different TranTypes.
I compared my values with the "running total" from the Part Transaction History Tracker
