BAQ help - get first
I am creating a query to get the first shipment date of a serial number - I am getting STK-CUS and MFG-CUS. I am using the SNTrans table. I displaying the part number, serialno, transdate, job and it linked to Customer table, and I am getting the CustID and Name.
I have excluded RMA’s -
When I run the query, it only gets one record.
Any suggestions
FWIW - In V8, using “First” and “Last” in BAQ’s wasn’t reliable.
What do you consider “the first record”? the one with the lowest TranNum? Earliest ship date?
This code should be close (off the cuff):
DEF VAR firstTranDate as DATE no-undo.
FOR EACH SNTrans fields (PartNum SerialNum TranDate JobNum) no-lock WHERE SNTrans.Company = cur-comp and SNTrans.PartNum = "XYZ" and SNTrans.SerialNum = "1234" and (SNTrans.TranType = "STK-CUS" or SNTrans.TranType = "MFG-CUS"),
	EACH Customer fields(Name CustID) no-lock WHERE Customer.Company = SNTrans.Company and Customer.CustNum = SNTrans.CustNum ORDER BY SNTrans.TranDate DESC.
assign firstTranDate = SNTrans.TranDate.
END.
I was hoping that it would pick the first record based on Serial number and date. We have a progress database and I am working with a BAQ.
Ah then without code, I’m not sure this can be done.
I use a uBAQ to update a calculated field with this code in GetList. I would additionally populate the Customer/ID with this code because the summary info is not robust in E9 BAQs.
