Hi Keith,
Mark W.
>On your server is a link called "Admin Tools". You log in as manager and then select Run Conversion Programs. The scroll bar is wacked. You can't just grab the square and pull it down to see all of the programs - you have to click on the down arrow in the scroll-bar. (At least, that's been my experience) Find 6430 and run it. You can run from the menu or right-mouse click it. . All it does is read the bin records and updates the totals in the PartWhse (and PartDtl?) records. Epicor recommends running it while there's no activity and depending how it's coded, that might be a good idea.
>How do a run Conversion program 6430?
Mark W.
