BAQ is V8 and E9 the same? Prompts?
Good Day:
Sun Is on M2K but,
Going to: Epicor 9, 9.04 ( maybe 9.05), SQL (live 7/1/2010- maybe
8/1/10)
Attached are some screen shots from E9 BAQ design screen.
Questions:
1. Is it similar to V8 BAQ so that V8 and E9 users can help each other?
Or, more precisely, V8 users can help me in E9 right now.
2. Specific question. Can a BAQ (NOT the one SHOWN) Prompt for a
parameter; for example, if a BAQ lists a BOM can it be programmed to
have a Screen prompt to ask for the Parent Part#
On Page 5 of attached, there is a criteria of ' Specified table
field value". If you select that, then click on "Specified", it opens up
a window with Field names. But, if I do that, when I run the BAQ, it
does not prompt me for the Parent_Part#, it just runs for the whole BOM
file.
I know that you usually run a Crystal report against the BAQ, but we
were told it is best to limit the number of records with the BAQ, so the
Crystal report runs faster.
I did the BAQ on-line ( actually on our server) course, and it did
not mention prompts\run-time-parameters.
len.hartka@...
<BLOCKED::mailto:len.hartka@...>
Leonard C. Hartka, IT Director\ERP Manager
Sun Automation Group
66 Loveton Circle
Sparks, Md. 21152
410-329-3560 ext. 120
410-329-3564 FAX
443-255-7192 Work Cell
len.hartka@...
www.Sunautomation.com <BLOCKED::http://www.sunautomation.com/>
Celebrating
25 Years of Service
to the Corrugated Industry
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
