BAQ Issue Blank Title 100061
Thanks Mr. Roel it worked out for me. Now I got the results
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Tue, April 26, 2011 6:02:34 PM
Subject: RE: [Vantage] BAQ Issue
I just tried and, you have to leave the (Vendor.APAcctID = ) blank. In other
words, instead of typing “” or ‘’ in the CONSTANT field, just leave it blank.
I hope it is not only my version (8.03.407)….
Regards.
Roel Martinez
ERP Analyst
SABRE TUBULAR STRUCTURES â„¢
www.sabretubularstructures.com<http://www.sabretubularstructures.com/>
8653 E. Hwy 67 | Alvarado, TX 76009
Phone: 817-852-1700 ext. 11858 | Direct Line: 817-852-1858 |Fax: 817-852-1705
Sreejith Jaganathan
Sent: Tuesday, April 26, 2011 7:47 AM
Subject: [Vantage] BAQ Issue
Good Afternoon
Thanks Mr. Martinez for responding I tried the below said but it didn't worked
out. If anybody could help me out with some other way.
Regards
Sreejith J
From: Roel Martinez <rmartinez@...<mailto:rmartinez%40sabre-sts.com>>
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>"
<vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Sent: Tue, April 26, 2011 3:51:51 PM
Good morning.
You can try matching the APAcctID to a "known" null field within the table, for
instance:
for each Vendor where ( Vendor.APAcctID = Vendor.Character05) no-lock
It has worked in a couple of BAQs but not in others for me in the past.....
don't know exactly why but hope it works for you.
Regards.
Roel Martinez
ERP Analyst
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Sreejith Jaganathan
Sent: Tuesday, April 26, 2011 5:04 AM
To: Vantage Group
Hi Friends
I am trying to find out the list of Vendors to which an AP Account is not
connected.
With the below 2 queries I didn't get any results
for each Vendor where ( Vendor.APAcctID = 'NULL') no-lock .
for each Vendor where ( Vendor.APAcctID = '""') no-lock .
I know that I am missing a simple point some where. Could any body please let me
know how to get the results for the query.
Regards
Sreejith J
Hi Friends
connected.
Regards
Sreejith J
Good morning.
You can try matching the APAcctID to a "known" null field within the table, for instance:
It has worked in a couple of BAQs but not in others for me in the past..... don't know exactly why but hope it works for you.
Regards.
Roel Martinez
ERP Analyst
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Sreejith Jaganathan
To: Vantage Group
Hi Friends
connected.
Regards
Sreejith J
Good Afternoon
Regards
Sreejith J
Good morning.
instance:
Regards.
Roel Martinez
ERP Analyst
Sreejith Jaganathan
To: Vantage Group
Hi Friends
connected.
Regards
Sreejith J
field = ''
should match empty text fields. If you're not getting the results you
expect, you may have an error elsewhere in your code. Can you post your
whole query?
On Tue, Apr 26, 2011 at 8:47 AM, Sreejith Jaganathan <
sreesvantagedoubts@...> wrote:
> Good Afternoon
> worked
> Regards
> Sreejith J
> From: Roel Martinez <rmartinez@...>
> Good morning.
> for
> instance:
> Regards.
> Roel Martinez
> ERP Analyst
> Of
> Sreejith Jaganathan
> To: Vantage Group
> Hi Friends
> connected.
> let me
> Regards
> Sreejith J
I just tried and, you have to leave the (Vendor.APAcctID = ) blank. In other words, instead of typing “” or ‘’ in the CONSTANT field, just leave it blank.
Regards.
Roel Martinez
ERP Analyst
Good Afternoon
Regards
Sreejith J
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Good morning.
instance:
Regards.
Roel Martinez
ERP Analyst
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Sreejith Jaganathan
To: Vantage Group
Hi Friends
connected.
Regards
Sreejith J
Sreejith, there is another trick available if the setting below doesn’t work.
Link your Vendor table to the APAcct one through “Company” and “APAcctID”, checking the “outerjoin” checkbox to get all vendors regardless of a record existing in the APAcct table; then in the Select criteria for APAcct, create one where APAcctID <> Vendor.APAcctID (deselecting “constant” checkbox).
This will bring both, Vendors without an APAcctID and Vendors with APAcctID but no link to APAcct table.
Hope this helps, too.
Roel Martinez
ERP Analyst
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Roel Martinez
Sent: Tuesday, April 26, 2011 9:03 AM
Regards.
Roel Martinez
ERP Analyst
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Sreejith Jaganathan
Good Afternoon
Regards
Sreejith J
From: Roel Martinez <rmartinez@...<mailto:rmartinez%40sabre-sts.com><mailto:rmartinez%40sabre-sts.com>>
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>>
Good morning.
instance:
Regards.
Roel Martinez
ERP Analyst
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of
Sreejith Jaganathan
To: Vantage Group
Hi Friends
connected.
Regards
Sreejith J
