Hello,
As someone new to BAQ, could someone tell me the best way to do a left outer join in this tool?
Pete
Hello,
Pete
Make a link between the two tables to join. Select that link, and then in the relationship pane below, there is a dropdown to specify the JOIN type. The description of the dropdown items varies depending on your version of E10
Click on the join, then the drop down at the bottom corner is the same as left/right/outer/inner. Different names, but if you read what it says, it’s not too hard to figure out.
excellent - Thank you!
screenshot helped - Thanks
