BAQ limit record for 7 days
I got a BAQ that a previous employee made years ago. It’s a production status report for every week.
It’s quite complicated (honestly overly complicated) and makes a number of subqueries. Do not have the time to rewrite it as of now but I need to fix it.
The issue is and has been from the get go, it’s getting 14 days of production status. I need 7. No where in the query does it show a limit for 14 days. Either I’m missing it or there is more to the story.
Maybe Crystal reports is what is filtering the data but I haven’t found anything in that, that could do that. Maybe someone could suggest something to look at.
Here is the query:
select distinct
[ProdGrup].[Description] as [ProdGrup_Description],
[JobHead].[JobNum] as [JobHead_JobNum],
[JobHead].[CreateDate] as [JobHead_CreateDate],
[JobHead].[PartNum] as [JobHead_PartNum],
[JobHead].[PartDescription] as [JobHead_PartDescription],
[OrderHed].[OrderNum] as [OrderHed_OrderNum],
[OrderHed].[OrderAmt] as [OrderHed_OrderAmt],
[Customer].[Name] as [Customer_Name],
[SNTran].[SerialNumber] as [SNTran_SerialNumber],
((case when RcvHead.Received = 1 or len(VIN.Calculated_Character02) > 0 or VIN.Calculated_SNStatus = ‘Consumed’ then
‘ON GROUND’
else
‘NOT ON GROUND’ end)) as [Calculated_OrderStatus],
((case when upper(substring(ProdGrup.Description,11,13))=‘VAN’ then
‘VANS-SPECIALTY’
when upper(substring(ProdGrup.Description,1,8))=‘MOBILITY’ then
‘MOBILITY’
when upper(substring(ProdGrup.Description,1,4))=‘LABO’ then
when upper(substring(ProdGrup.Description,1,4))=‘WARR’ then
when upper(substring(ProdGrup.Description,1,4))=‘VANS’ then
when upper(substring(ProdGrup.Description,1,4))=‘CARS’ then
else
‘TRUCKS’ end)) as [Calculated_JobType],
((case when RcvHead.Received = 1 then
RcvHead.ArrivedDate
else (case when len(VIN.Calculated_Character02) > 0 or VIN.Calculated_SNStatus = ‘Consumed’ then
VIN.Calculated_Date01
else
NULL end) end)) as [Calculated_OnGroundDate],
[OrderHed].[OrderDate] as [OrderHed_OrderDate],
[OrderHed].[OpenOrder] as [OrderHed_OpenOrder],
[Part_Chassis].[ShortChar04] as [Part_Chassis_ShortChar04],
((case when convert(int, InvcHead.InvoiceNum) = 10135 or convert(int, InvcHead.InvoiceNum) = 10136 then
0
else (case when JobHead.JobClosed = 0 then
1
else (case when ((InvcHead.InvoiceNum) = null) and JobHead.JobClosed = 1 then
0
else (case when InvcHead.OpenInvoice = 1 then
1
else
0 end) end) end) end)) as [Calculated_OpenJob],
[JobHead].[JobCompletionDate] as [JobHead_JobCompletionDate],
[JobHead].[ReqDueDate] as [JobHead_ReqDueDate],
[SalesRep].[Name] as [SalesRep_Name],
[JobHead].[QuoteNum] as [JobHead_QuoteNum],
[JobHead].[ShortChar01] as [JobHead_ShortChar01],
[JobHead].[StartDate] as [JobHead_StartDate],
[JobHead].[DueDate] as [JobHead_DueDate],
[JobHead].[JobClosed] as [JobHead_JobClosed],
[JobHead].[CheckBox01] as [JobHead_CheckBox01],
[OrderHed].[SalesRepList] as [OrderHed_SalesRepList],
[InvcHead].[InvoiceNum] as [InvcHead_InvoiceNum],
[JobHead].[WIStartDate] as [JobHead_WIStartDate],
(ISNULL(JobMatlFlags.Calculated_JobHasTintMtl,‘N’)) as [Calculated_Tint],
(ISNULL(JobMatlFlags.Calculated_JobHasLiner,‘N’)) as [Calculated_Allign],
(ISNULL(JobMatlFlags.Calculated_JobHasLeather,‘N’)) as [Calculated_Leather],
(ISNULL(JobMatlFlags.Calculated_JobHasPaintedParts,‘N’)) as [Calculated_Paint],
[LastInvoice].[Calculated_Invoice] as [Calculated_Invoice],
[VIN].[Calculated_VIN] as [Calculated_VIN],
[VIN].[Part2_ShortChar04] as [Part2_ShortChar04],
[JobHead].[Date01] as [JobHead_Date01],
[ProdGrup].[ProdCode] as [ProdGrup_ProdCode]
from Erp.JobHead as JobHead
inner join Erp.Part as Part on
JobHead.Company = Part.Company
and JobHead.PartNum = Part.PartNum
and ( not Part.ProdCode in (‘LABOR’, ‘WARRANTY’) )
left outer join Erp.ProdGrup as ProdGrup on
Part.Company = ProdGrup.Company
and Part.ProdCode = ProdGrup.ProdCode
inner join Erp.JobProd as JobProd on
JobHead.Company = JobProd.Company
and JobHead.JobNum = JobProd.JobNum
inner join Erp.OrderHed as OrderHed on
JobProd.Company = OrderHed.Company
and JobProd.OrderNum = OrderHed.OrderNum
left outer join Erp.SalesRep as SalesRep on
OrderHed.Company = SalesRep.Company
and OrderHed.SalesRepList = SalesRep.SalesRepCode
inner join Erp.Customer as Customer on
OrderHed.Company = Customer.Company
and OrderHed.CustNum = Customer.CustNum
left outer join Erp.InvcHead as InvcHead on
JobProd.Company = InvcHead.Company
and JobProd.OrderNum = InvcHead.OrderNum
left outer join (select
[InvcHead1].[Company] as [InvcHead1_Company],
[InvcHead1].[OrderNum] as [InvcHead1_OrderNum],
(max(InvcHead1.InvoiceNum)) as [Calculated_Invoice]
from Erp.InvcHead as InvcHead1
group by InvcHead1.Company,InvcHead1.OrderNum) as LastInvoice on
LastInvoice.InvcHead1_Company = InvcHead.Company
and LastInvoice.InvcHead1_OrderNum = InvcHead.OrderNum
and LastInvoice.Calculated_Invoice = InvcHead.InvoiceNum
left outer join Erp.SNTran as SNTran on
JobHead.Company = SNTran.Company
and JobHead.JobNum = SNTran.JobNum
and ( SNTran.TranType = ‘STK-MTL’ )
left outer join Erp.RcvHead as RcvHead on
SNTran.Company = RcvHead.Company
and SNTran.PurPoint = RcvHead.PurPoint
and SNTran.VendorNum = RcvHead.VendorNum
and SNTran.PackSlip = RcvHead.PackSlip
left outer join Erp.SerialNo as SerialNo on
SNTran.Company = SerialNo.Company
and SNTran.PartNum = SerialNo.PartNum
and SNTran.SerialNumber = SerialNo.SerialNumber
left outer join Erp.Part as Part_Chassis on
SerialNo.Company = Part_Chassis.Company
and SerialNo.PartNum = Part_Chassis.PartNum
left outer join Erp.JobMtl as JobMtl on
JobMtl.Company = SNTran.Company
and JobMtl.JobNum = SNTran.JobNum
and JobMtl.PartNum = SNTran.PartNum
[JobMtl1].[Company] as [JobMtl1_Company],
[JobMtl1].[JobNum] as [JobMtl1_JobNum],
(max(case when JobMtl1.PartNum like ‘VOR.%’ then ‘Y’ else ‘N’ end)) as [Calculated_JobHasLiner],
(max(case when isnull(JobMtl1.Description,’’) like ‘%LEATHER%’ then ‘Y’ else ‘N’ end)) as [Calculated_JobHasLeather],
(max(case when JobMtl1.PartNum like ‘WCT.%’ then ‘Y’ else ‘N’ end)) as [Calculated_JobHasTintMtl],
(max(case when JobMtl1.PartNum like ‘WPP.%’ then ‘Y’ else ‘N’ end)) as [Calculated_JobHasPaintedParts]
from Erp.JobMtl as JobMtl1
left outer join Erp.Part as Part3 on
JobMtl1.Company = Part3.Company
and JobMtl1.PartNum = Part3.PartNum
left outer join Erp.ProdGrup as ProdGrup1 on
Part3.Company = ProdGrup1.Company
and Part3.ProdCode = ProdGrup1.ProdCode
where (JobMtl1.PartNum like ‘VOR%’ or JobMtl1.PartNum like ‘WCT%’ or (JobMtl1.Description like ‘%LEATHER%’ or JobMtl1.PartNum like ‘WPP%’ and not ProdGrup1.Description like ‘CHASSIS%’ ))
group by JobMtl1.Company,JobMtl1.JobNum) as JobMatlFlags on
JobMatlFlags.JobMtl1_Company = JobHead.Company
and JobMatlFlags.JobMtl1_JobNum = JobHead.JobNum
[JobAsmbl].[Company] as [JobAsmbl_Company],
[JobAsmbl].[JobNum] as [JobAsmbl_JobNum],
(max(case when JobAsmbl.PartNum like ‘%.T023%’ then ‘Y’ else ‘N’ end)) as [Calculated_HasLeather]
from Erp.JobAsmbl as JobAsmbl
group by JobAsmbl.Company,JobAsmbl.JobNum) as JobAsmFlags on
JobAsmFlags.JobAsmbl_Company = JobHead.Company
and JobAsmFlags.JobAsmbl_JobNum = JobHead.JobNum
[SNTran1].[Company] as [SNTran1_Company],
[SNTran1].[JobNum] as [SNTran1_JobNum],
[Part2].[ShortChar04] as [Part2_ShortChar04],
(MAX(SNTran1.SerialNumber)) as [Calculated_VIN],
(MAX(SerialNo1.SNStatus)) as [Calculated_SNStatus],
(MAX(SerialNo1.Character02)) as [Calculated_Character02],
(MAX(SerialNo1.Date01)) as [Calculated_Date01]
from Erp.SNTran as SNTran1
inner join Erp.JobMtl as JobMtl2 on
JobMtl2.Company = SNTran1.Company
and JobMtl2.JobNum = SNTran1.JobNum
and JobMtl2.PartNum = SNTran1.PartNum
inner join Erp.Part as Part2 on
Part2.Company = JobMtl2.Company
and Part2.PartNum = JobMtl2.PartNum
inner join Erp.SerialNo as SerialNo1 on
SerialNo1.Company = SNTran1.Company
and SerialNo1.PartNum = SNTran1.PartNum
and SerialNo1.SerialNumber = SNTran1.SerialNumber
where (JobMtl2.CheckBox01 = 0 and SNTran1.TranType = ‘STK-MTL’)
group by SNTran1.Company,SNTran1.JobNum,Part2.ShortChar04) as VIN on
VIN.SNTran1_Company = JobHead.Company
and VIN.SNTran1_JobNum = JobHead.JobNum
where (JobHead.JobNum <> ‘14877’ and JobHead.JobNum <> ‘14882’ and JobHead.JobNum <> ‘14870’ and JobHead.JobClosed = FALSE)
and (((case when convert(int, InvcHead.InvoiceNum) = 10135 or convert(int, InvcHead.InvoiceNum) = 10136 then
0
1
0
1
else
0 end) end) end) end)) = 1 and JobHead.CheckBox01 = 0 and (InvcHead.InvoiceNum is null or LastInvoice.InvcHead1_OrderNum is not null) and (JobMtl.JobNum is not null or SNTran.SerialNumber is null))
You probably need to put a criteria in against one of your date fields that is Currentdate-7
Is it possible the filtering is defined in the BAQ Report definition, and not the actual BAQ?
You’re on the money. It’s in the crystal report. Not in the BAQ.
I’m not terribly familiar to Crystal reports. I can add columns and move data around but the more technical stuff is a bit out of my realm.
I can tell the crystal report is doing the filtering but haven’t figured out how to modify it yet.
There is a Record Selection somewhere, I think under the Records menu.
