BAQ Link from Job to Ship To (Vantage 8.03)
Hi,
Thank you everyone for your input, it helped a lot. I finally
figured out how to make it work. In the Table Relations screen I was
linking Customer to ShipTo and Order Rel to Ship To. Once I removed
the link from Order Rel to Ship To, made the Customer link to Ship To
an Outer Join, then I setup a Criteria to filter for ShipTo.ShipToNum
= OrderRel.ShipToNum it worked just the way I wanted it to. Whoohoo!!
Linda
--- In vantage@yahoogroups.com, "Scott Litzau" <scott.litzau@...>
wrote:
> Linda,
> I am going to try to create a BAQ based on your criteria. I will
let you
> know my findings as soon as I can.
> Scott Litzau, MCP
> Olympus Flag & Banner
> Information Systems Manager
> scott.litzau@...
> P: 414-365-9732
> F: 414-355-1931
> -----Original Message-----
Behalf Of
> lindalowney
> Sent: Wednesday, June 18, 2008 7:13 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: BAQ Link from Job to Ship To (Vantage 8.03)
> Hi Scott,
> I need a list of open installation jobs showing the due date,
> scheduled date, the ship to name and address for our installation
> department. I've got everything but the ship to information. I
can
> get it to work sometimes, when Vantage does not freeze up, but it
> shows every ship to related to the customer and sometimes there are
> as many as a hundred of them. I'm thinking that maybe I will leave
> it like that and see if I can get rid of the unrelated ship to
> addresses in the dashboard.
> Since the ship to code is in the OrderRel table, I think they
should
> have also put the CustNum field there too.
> Linda
> --- In vantage@yahoogroups.com, "Scott Litzau" <scott.litzau@>
> wrote:
> > Linda,
> > What is your criteria you are trying to get at. Open Jobs, Open
> Orders,
> > already shipped jobs. If nothing has shipped that ShipHead and
> ShipDtl will
> > not be there since these are poputlated after shipment entry.
> > Scott Litzau, MCP
> > scott.litzau@
> > P: 414-365-9732
> > F: 414-355-1931
> Behalf Of
> > Ted Kitch
> > Sent: Tuesday, June 17, 2008 1:31 PM
> > Subject: RE: [Vantage] Re: BAQ Link from Job to Ship To (Vantage
> 8.03)
> > You will want to start with your ShipHead and ShipDtl tables and
> link your
> > way back to the jobs. ShipDtl will give you the jobnumber that
it
> ships
> > from and ShipHead will give you the date and customer details.
> > HTH,
> > Ted Kitch
> > Information Technology Manager
> > Astro Machine Corporation
> > www.astromachine.com
> Behalf Of
> > lindalowney
> > Sent: Tuesday, June 17, 2008 1:24 PM
> > Hi Scott,
> > Thank you. I've tried this too. I either get all ship to address
> > related to the customer or Vantage hangs up and I have to end the
> > process using task manager. I've tried using outer joins, no
outer
> > joins.
> > If I was doing it in Crystal it would be easy. The Vantage query
> > process is horrible. It would be nice if I could just set it up
in
> > Crystal then copy the SQL query to Vantage.
> > Linda
> > --- In vantage@yahoogroups.com <mailto:vantage%
> 40yahoogroups.com> , "Scott
> > wrote:
> > > Linda,
> > > I try to do more complicated BAQs in Crystal first so I can
> figure
> > out my
> > > linking of Tables and then translate that to a BAQ. Since BAQ
are
> > not as
> > > flexible as Crystal some things are just not possible.
> > > Also what is your criteria - Open Jobs?, Open Orders?. The
reason
> I
> > ask is
> > > because then it depends how you come at the data. I will assume
> > open jobs.
> > > I think you need the following Tables
> > > JobHead
> > > JobProd
> > > OrderRel
> > > OrdeHed
> > > Customer
> > > ShipTo
> > > Then Link
> > > JobHead to JobProd via JobNum
> > > JobProd to OrderRel via JobNum, OrderNum, and OrderRelNum
> > > OrderRel to OrderHed via OrderNum
> > > OrderHed to Customer via CustNum (I like CustNum because it can
> > never change
> > > where CustID can)
> > > Customer to Ship To via CustNum
> > > Hope this helps.
> > > Scott Litzau, MCP
> > > scott.litzau@
> > > P: 414-365-9732
> > > F: 414-355-1931
> > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > [mailto:vantage@yahoogroups.com <mailto:vantage%
> 40yahoogroups.com> ] On
> > Behalf Of
> > > lindalowney
> > > Sent: Tuesday, June 17, 2008 10:05 AM
> > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
8.03)
> > > Hi Rob,
> > > Thank you, but I tried that and it does not work.
> > > Regards,
> > > Linda
> 40yahoogroups.com> , Robert
> > Brown <robertb_versa@>
> > > wrote:
> > > > Add OrderDtl, OrderRel & JobProd to your query (also JobHead
if
> > you
> > > need Jobs basic status info and customer & customer shipto
> address
> > > tables if you need more detail than simple ID numbers).
> > > > The BAQ Phrase Builder wizard created joins should be fine.
> > > > Rob Brown
> > > > --- On Fri, 6/13/08, lindalowney <llowney@> wrote:
> > > > From: lindalowney <llowney@>
> > > > Subject: [Vantage] BAQ Link from Job to Ship To (Vantage 8.03)
40yahoogroups.com>
> > > > Date: Friday, June 13, 2008, 2:56 PM
> > > > Hi Group,
> > > > I'm trying to create a query that shows the job number, the
> > > customer
> > > > ship to name and address. As far as I can see I need the
> JobProd
> > > tble
> > > > to link back to the order release. The order release contains
> > the
> > > ship
> > > > to number, but not the customer. The order head contains both
> > > fields,
> > > > but doesn't help if each release has a different ship to
> number.
> > > Can
> > > > anyone point me in the right direction, please?
> > > > Linda Lowney
> > > > Pride Signs
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You
> > must have
> > > already linked your email address to a yahoo id to enable
> access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report
> > Builder and
> > > Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/.
> > <http://groups.yahoo.com/group/vantage/files/>
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must have
access. )
> Builder and
must have
Builder and
Hi Group,
I'm trying to create a query that shows the job number, the customer
ship to name and address. As far as I can see I need the JobProd tble
to link back to the order release. The order release contains the ship
to number, but not the customer. The order head contains both fields,
but doesn't help if each release has a different ship to number. Can
Linda Lowney
Pride Signs
Add OrderDtl, OrderRel & JobProd to your query (also JobHead if you need Jobs basic status info and customer & customer shipto address tables if you need more detail than simple ID numbers).
Rob Brown
Hi Group,
Linda Lowney
Pride Signs
Hi Rob,
Regards,
Linda
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
> Rob Brown
> From: lindalowney <llowney@...>
> Hi Group,
customer
tble
ship
fields,
Can
> Linda Lowney
> Pride Signs
Linda,
I try to do more complicated BAQs in Crystal first so I can figure out my
linking of Tables and then translate that to a BAQ. Since BAQ are not as
Also what is your criteria - Open Jobs?, Open Orders?. The reason I ask is
because then it depends how you come at the data. I will assume open jobs.
JobHead
JobProd
OrderRel
OrdeHed
Customer
ShipTo
Then Link
OrderHed to Customer via CustNum (I like CustNum because it can never change
where CustID can)
Hope this helps.
Scott Litzau, MCP
scott.litzau@...
P: 414-365-9732
F: 414-355-1931
lindalowney
Hi Rob,
Regards,
Linda
> Rob Brown
> Hi Group,
customer
tble
ship
fields,
Can
> Linda Lowney
> Pride Signs
For complicated BAQs, I try to start with the table(s) that have selection
criteria and run the BAQ to make sure that I've set the selection criteria
properly. Next, I add one table at a time to make sure that I've linked
properly. If at any point all of the records disappear at least I know what
step is messing me up.
Mark W.
Hi Scott,
process using task manager. I've tried using outer joins, no outer
joins.
process is horrible. It would be nice if I could just set it up in
Linda
wrote:
> Linda,
out my
not as
ask is
open jobs.
> JobHead
> JobProd
> OrderRel
> OrdeHed
> Customer
> ShipTo
> Then Link
never change
> where CustID can)
> Hope this helps.
> Scott Litzau, MCP
> scott.litzau@...
> P: 414-365-9732
> F: 414-355-1931
Behalf Of
> lindalowney
> Hi Rob,
> Regards,
> Linda
> --- In vantage@yahoogroups.com, Robert Brown <robertb_versa@>
you
> > Rob Brown
> > Hi Group,
> customer
> tble
the
> ship
> fields,
> Can
> > Linda Lowney
> > Pride Signs
must have
Builder and
You will want to start with your ShipHead and ShipDtl tables and link your
way back to the jobs. ShipDtl will give you the jobnumber that it ships
HTH,
Ted Kitch
lindalowney
Hi Scott,
joins.
Linda
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Scott
wrote:
> Linda,
out my
not as
ask is
open jobs.
> JobHead
> JobProd
> OrderRel
> OrdeHed
> Customer
> ShipTo
> Then Link
never change
> where CustID can)
> Hope this helps.
> Scott Litzau, MCP
> scott.litzau@...
> P: 414-365-9732
> F: 414-355-1931
Behalf Of
> lindalowney
> Hi Rob,
> Regards,
> Linda
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Robert
you
> > Rob Brown
> > Hi Group,
> customer
> tble
the
> ship
> fields,
> Can
> > Linda Lowney
> > Pride Signs
must have
Builder and
Linda,
What is your criteria you are trying to get at. Open Jobs, Open Orders,
already shipped jobs. If nothing has shipped that ShipHead and ShipDtl will
Scott Litzau, MCP
scott.litzau@...
P: 414-365-9732
F: 414-355-1931
Ted Kitch
Subject: RE: [Vantage] Re: BAQ Link from Job to Ship To (Vantage 8.03)
HTH,
Ted Kitch
lindalowney
Hi Scott,
joins.
Linda
wrote:
> Linda,
out my
not as
ask is
open jobs.
> JobHead
> JobProd
> OrderRel
> OrdeHed
> Customer
> ShipTo
> Then Link
never change
> where CustID can)
> Hope this helps.
> Scott Litzau, MCP
> scott.litzau@...
> P: 414-365-9732
> F: 414-355-1931
Behalf Of
> lindalowney
> Hi Rob,
> Regards,
> Linda
you
> > Rob Brown
> > Hi Group,
> customer
> tble
the
> ship
> fields,
> Can
> > Linda Lowney
> > Pride Signs
must have
Builder and
Then you join columns between the tables are wrong (and perhaps the phrase builder's choices aren;t what you need.
I've got a nearly a 1/2 dozen BAQs (varitions on your theme so similar) that work just fine on 404.
Rob Brown
Date: Tuesday, June 17, 2008, 11:05 AM
Hi Rob,
Regards,
Linda
--- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ ...>
> Rob Brown
> --- On Fri, 6/13/08, lindalowney <llowney@... > wrote:
> From: lindalowney <llowney@... >
> To: vantage@yahoogroups .com
> Hi Group,
customer
tble
ship
fields,
Can
> Linda Lowney
> Pride Signs
Hi Ted,
Thank you Ted, but the jobs have not shipped yet.
Linda
link your
ships
> HTH,
> Ted Kitch
Behalf Of
> lindalowney
> Hi Scott,
> joins.
> Linda
> wrote:
> > Linda,
figure
> out my
> not as
I
> ask is
> open jobs.
> > JobHead
> > JobProd
> > OrderRel
> > OrdeHed
> > Customer
> > ShipTo
> > Then Link
> never change
> > where CustID can)
> > Hope this helps.
> > Scott Litzau, MCP
> > scott.litzau@
> > P: 414-365-9732
> > F: 414-355-1931
> Behalf Of
> > lindalowney
> > Hi Rob,
> > Regards,
> > Linda
> you
address
> > > Rob Brown
> > > Hi Group,
> > customer
JobProd
> > tble
> the
> > ship
> > fields,
number.
> > Can
> > > Linda Lowney
> > > Pride Signs
> must have
access. )
> Builder and
Hi Scott,
department. I've got everything but the ship to information. I can
Since the ship to code is in the OrderRel table, I think they should
Linda
wrote:
> Linda,
Orders,
ShipDtl will
> Scott Litzau, MCP
> scott.litzau@...
> P: 414-365-9732
> F: 414-355-1931
Behalf Of
> Ted Kitch
8.03)
link your
ships
> HTH,
> Ted Kitch
Behalf Of
> lindalowney
> Hi Scott,
> joins.
> Linda
> wrote:
> > Linda,
figure
> out my
> not as
I
> ask is
> open jobs.
> > JobHead
> > JobProd
> > OrderRel
> > OrdeHed
> > Customer
> > ShipTo
> > Then Link
> never change
> > where CustID can)
> > Hope this helps.
> > Scott Litzau, MCP
> > scott.litzau@
> > P: 414-365-9732
> > F: 414-355-1931
> Behalf Of
> > lindalowney
> > Hi Rob,
> > Regards,
> > Linda
> you
address
> > > Rob Brown
> > > Hi Group,
> > customer
JobProd
> > tble
> the
> > ship
> > fields,
number.
> > Can
> > > Linda Lowney
> > > Pride Signs
> must have
access. )
> Builder and
must have
Builder and
Sorry for the misunderstanding, have you tried the following: (just thinking
out loud on this as we don't do service calls)
Link back to OrderRel and then link up to OrderDtl which has the customer
number. You could then try creating a link from OrderDtl.CustNum to
ShipTo.CustNum and OrderRel.ShipToNum to ShipTo.ShipToNum.
This sounds like a pretty serious oversight on the programmers on how they
implemented this feature. It would make sense to want the ability to see
all open jobs with their destinations.
HTH,
Ted Kitch
lindalowney
Hi Scott,
Linda
wrote:
> Linda,
Orders,
ShipDtl will
> Scott Litzau, MCP
> scott.litzau@...
> P: 414-365-9732
> F: 414-355-1931
Behalf Of
> Ted Kitch
8.03)
link your
ships
> HTH,
> Ted Kitch
Behalf Of
> lindalowney
> Hi Scott,
> joins.
> Linda
<mailto:vantage%
> wrote:
> > Linda,
figure
> out my
> not as
I
> ask is
> open jobs.
> > JobHead
> > JobProd
> > OrderRel
> > OrdeHed
> > Customer
> > ShipTo
> > Then Link
> never change
> > where CustID can)
> > Hope this helps.
> > Scott Litzau, MCP
> > scott.litzau@
> > P: 414-365-9732
> > F: 414-355-1931
<mailto:vantage%
> Behalf Of
> > lindalowney
> > Hi Rob,
> > Regards,
> > Linda
<mailto:vantage%
> you
address
> > > Rob Brown
> > > Hi Group,
> > customer
JobProd
> > tble
> the
> > ship
> > fields,
number.
> > Can
> > > Linda Lowney
> > > Pride Signs
> must have
access. )
> Builder and
must have
Builder and
Customer is Order specific (only one customer per sales order) & it makes no sense to design a db schema where they redundantly appear in the OrderDtl or OrderRel table.
Ship-to (and Ship Via, etc.,) are OrderRel specific - and that is why you can over-ride these values at the release.
The tables that define pack IDs and details within those IDs (pending shipments) are flaky. The BAQ phrase builder overlinks tables when these tables are involved. I've forgotten which key column it is, but one of the columns in these tables (on 404) isn't being populated by the applications so the expected normal key column links result in no data returned.
I'm remote right now and can't access Vantage but it is something exceeding dumb (and a clear unadmitted to by Vantage application bug) like the Company column values being left null in one of the pack out tables.
Make a note of the column links the BAQ phrase builder sets up between your multiple selected table.
Then look at the tables one at a time via BAQ and inspect the contents of those 'key' columns.
I think you will quickly find one of them is full of null value data and the source of your problems.
Rob Brown
Date: Wednesday, June 18, 2008, 8:13 AM
Hi Scott,
Linda
--- In vantage@yahoogroups .com, "Scott Litzau" <scott.litzau@ ...>
wrote:
> Linda,
Orders,
ShipDtl will
> Scott Litzau, MCP
> scott.litzau@ ...
> P:
> F:
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf Of
> Ted Kitch
8.03)
link your
ships
> HTH,
> Ted Kitch
> www.astromachine. com
Behalf Of
> lindalowney
> Hi Scott,
> joins.
> Linda
> --- In vantage@yahoogroups .com <mailto:vantage%
40yahoogroups. com> , "Scott
> Litzau" <scott.litzau@ >
> wrote:
> > Linda,
figure
> out my
> not as
I
> ask is
> open jobs.
> > JobHead
> > JobProd
> > OrderRel
> > OrdeHed
> > Customer
> > ShipTo
> > Then Link
> never change
> > where CustID can)
> > Hope this helps.
> > Scott Litzau, MCP
> > scott.litzau@
> > P:
> > F:
> > From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> [mailto:vantage@yahoogroups .com <mailto:vantage%
40yahoogroups. com> ] On
> Behalf Of
> > lindalowney
> > Sent: Tuesday, June 17, :05 AM
> > To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> > Hi Rob,
> > Regards,
> > Linda
40yahoogroups. com> , Robert
> Brown <robertb_versa@ >
> you
address
> > > Rob Brown
> > > Hi Group,
> > customer
JobProd
> > tble
> the
> > ship
> > fields,
number.
> > Can
> > > Linda Lowney
> > > Pride Signs
> must have
access. )
> Builder and
> > http://groups. yahoo.com/ group/vantage/ files/.
> <http://groups. yahoo.com/ group/vantage/ files/>
> > http://groups. yahoo.com/ group/vantage/ messages
> > http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
must have
Builder and
Linda,
I am going to try to create a BAQ based on your criteria. I will let you
Scott Litzau, MCP
scott.litzau@...
P: 414-365-9732
F: 414-355-1931
lindalowney
Hi Scott,
Linda
wrote:
> Linda,
Orders,
ShipDtl will
> Scott Litzau, MCP
> scott.litzau@...
> P: 414-365-9732
> F: 414-355-1931
Behalf Of
> Ted Kitch
8.03)
link your
ships
> HTH,
> Ted Kitch
Behalf Of
> lindalowney
> Hi Scott,
> joins.
> Linda
> wrote:
> > Linda,
figure
> out my
> not as
I
> ask is
> open jobs.
> > JobHead
> > JobProd
> > OrderRel
> > OrdeHed
> > Customer
> > ShipTo
> > Then Link
> never change
> > where CustID can)
> > Hope this helps.
> > Scott Litzau, MCP
> > scott.litzau@
> > P: 414-365-9732
> > F: 414-355-1931
> Behalf Of
> > lindalowney
> > Hi Rob,
> > Regards,
> > Linda
> you
address
> > > Rob Brown
> > > Hi Group,
> > customer
JobProd
> > tble
> the
> > ship
> > fields,
number.
> > Can
> > > Linda Lowney
> > > Pride Signs
> must have
access. )
> Builder and
must have
Builder and
I tried just using the minimum number of tables and it still does not
work correctly. I setup the phrase builder like this:
ParentData ChildData Outer Field
TableId KeyId TableId Join Relations
OrderHed OrderNum OrderRel No Company/ShipToNum
OrderHed BTCustNum ShipTo No Company/BTCustNum
(to CustNum)
OrderRel OrderShipToRel ShipTo No Company/ShipToNum
It takes 3 to 4 minutes to run and I get this:
Ord# OrdLn OrderRel OrderHed ShipTo OrderRel ShipTo
BTCustNum CustNum ShipTo ShipTo
17017 1 1 249 0000335 0306 0306
17017 1 1 249 0000590 0306 0306
17017 1 1 249 0000029 0306 0306
17017 1 1 249 0000249 0306 0306
Several pages of this for each order.
I've been working on this for days and it's driving me crazy. If
they would use a report instead I could have had this all done in
Crystal days ago.
Is there something wrong with the linking? I've tried turning on
outer join and it does not seem to make any difference.
Linda
thinking
customer
how they
to see
> HTH,
> Ted Kitch
Behalf Of
> lindalowney
> Hi Scott,
should
> Linda
> wrote:
> > Linda,
> Orders,
> ShipDtl will
> > Scott Litzau, MCP
> > scott.litzau@
> > P: 414-365-9732
> > F: 414-355-1931
> Behalf Of
> > Ted Kitch
> 8.03)
> link your
> ships
> > HTH,
> > Ted Kitch
> Behalf Of
> > lindalowney
> > Hi Scott,
outer
> > joins.
in
> > Linda
> <mailto:vantage%
> > wrote:
> > > Linda,
> figure
> > out my
are
> > not as
reason
> I
> > ask is
> > open jobs.
> > > JobHead
> > > JobProd
> > > OrderRel
> > > OrdeHed
> > > Customer
> > > ShipTo
> > > Then Link
> > never change
> > > where CustID can)
> > > Hope this helps.
> > > Scott Litzau, MCP
> > > scott.litzau@
> > > P: 414-365-9732
> > > F: 414-355-1931
> <mailto:vantage%
> > Behalf Of
> > > lindalowney
8.03)
> > > Hi Rob,
> > > Regards,
> > > Linda
40yahoogroups.com>
> <mailto:vantage%
if
> > you
> address
> > > > Rob Brown
> > > > Hi Group,
> > > customer
> JobProd
> > > tble
> > the
> > > ship
> > > fields,
> number.
> > > Can
> > > > Linda Lowney
> > > > Pride Signs
You
> > must have
> access. )
> > Builder and
> must have
access. )
> Builder and
