BAQ -- Multi-Company -- Vantage 8.03.404
Dear Kevin:
Thanks very much for your replies.
I just received an email from Epicor Support regarding my call. The
email is instructing me to do everything that I have already done the
past 2 days: Make the BAQ shared & global and make sure Sonic is
installed and running.
I will call the number she gave me in the email.
Lynn
--- In vantage@yahoogroups.com, "Kevin Kadamus" <kkadamus@...> wrote:
> Lynn,
> Sorry for not getting back to you sooner, I was out most of the day.
> You seem to be on the right track; however you will need to know if
you have
> all of the proper check boxes checked throughout the system.
> I would recommend a call to your CAM to see if you can get
any "free"
> (ha-ha) advice or if Epicor could look at your configuration.
> There are several ways to set up what you are doing. I have
clients that
> have Multi-site / multi-companies that only allow global BAQ's for
some of
> their divisions while others are completely independent of each
other. That
> is why I was asking you how you have set up your Db's. There are
many
> decisions to make when you set up your multi-company solution.
Without
> seeing how you are set up I can only speculate what may or may not
be set up
> or missing in your configuration.
> Are you running SQL or just Progress? You have other options
depending on
> how you set up your environment, one server, multiple servers,
SANS, etc. It
> can get very detailed in a hurry.
> Good luck on your quest for multi-company knowledge! You can give
me a call
> if you have any other questions.
> Thank you,
> Kevin Kadamus
> Senior Consultant
> Epicor Authorized Partner
> kkadamus@...
> 952-905-0387
> CONFIDENTIALITY NOTICE: This electronic email transmission may
contain
> consultant/client privilege and confidential information intended
only for
> the individual or entity named above. Any dissemination, use,
distribution,
> copying or disclosure of this communication by any other person or
entity is
> strictly prohibited. Should you receive this transmission in error,
please
> notify the sender by telephone at 952-905-0387.
> _____
Behalf Of
> Lynn
> Sent: Friday, July 11, 2008 11:41 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: BAQ -- Multi-Company -- Vantage 8.03.404
> OK, I went into Multi-Company Server Process and the box is checked
> for Continuous Processing, 1 minute delay, Schedule "Now", and
there
> is a log filename.
> Then I went in to System Agent Maintenance and saw that
> SystemTaskAgent is started and Multi-Company Process is listed as a
> task.
> Everything seems to look good. I have rebooted Vantage dozens of
> times; I still can't see A-BOM BAQ while in company CORE. But, I
> sure am learning a lot about multi-company data transfers for
future
> reference.
> Lynn
> --- In vantage@yahoogroups <mailto:vantage%
40yahoogroups.com> .com, "Daniel
> Laidig" <daniellaidig@>
> wrote:
> > One other thing that you have to do is run the MultiCompany
Server
> Process
> > for Sonic to be able to pick up your newly created BAQ and
transfer
> it to
> > another company. Have you tried running that? System Management >
> > utilities > Multi-Company Server Process.
> > Daniel Laidig
> > Laidig Systems, Inc.
> > (574) 256-0204 ext. 229
> > <mailto:daniellaidig@> daniellaidig@
> > _____
> > From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> [mailto:vantage@yahoogroups <mailto:vantage%
40yahoogroups.com> .com] On
> Behalf Of
> > Lynn
> > Sent: Friday, July 11, 2008 8:49 AM
> > To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> > We do have Sonic installed and running. I know its working
because
> I
> > can use other BAQs that were created in other companies.
> > I didn't know about the "External Companies" in User Maintenance
so
> I
> > tried it. No luck. I went in to company CORE user maintenance and
> > added A then logged off. Then I went in to company A user
> > maintenance and added CORE.
> > Then I rebooted Vantage, logged back in to CORE and tried to see
> the
> > BAQ named A-BOM. I still cannot see it.
> > What makes this so puzzling is that when I am in company CORE, I
> can
> > use other A- BAQs. It is only this one I cannot see, which
happens
> > to be the most complicated and most important one of all.
> > I'm beginning to think it is a bug. I put a call in to Support.
> > Thanks for educating me on the user maintenance requirement for
the
> > Multi-company dashboards!
> > Lynn
> > wrote:
> > > That is true in 8.03.4xx. Before, you didn't have to have Sonic
> > for Global
> > > BAQ. Also, in order to access the BAQ on a dashboard in other
> > companies,
> > > your users must be set up with the appropriate "external
> companies"
> > in User
> > > Maintenance and they will have to sign into the other company
> every
> > time the
> > > dashboard is run. It is really a pain.
> > > Daniel Laidig
> > > _____
> > Behalf Of
> > > Nigel Kerley
> > > Sent: Friday, July 11, 2008 4:39 AM
> > > I THINK that in order for the "Global" checkbox to copy the BAQ
> > > across companies, you have to have Sonic installed/running.
> > > Nigel.
> > Jennifer
> > > George <jgeorge@> wrote:
> > > > Lynn & Kevin -
> > > > I am running into the same issue. CompanyA & CompanyB both
want
> > > the BAQ names to be A-xxx and B-xxx. I created the original BAQ
> (A-
> > > rpt) in Company A. I can export/import, but it wants it to be B-
> > > rpt. Although, I have checked the Global box and I can see it
in
> > > company B in Report Designer. If I choose A-rpt. It tells me
the
> > > BAQ does not exist.
> > > > I will have to do this for several reports and do not want to
> > > recreate the BAQ, etc. over and over again.
> > > > I am new to Vantage, so if there is a setup issue, can
someone
> > > please explain it to me?
> > > > Like Lynn, I do not want to have to waste time doing
recreation.
> > > > Thanks!
> > > > jen
> > > > ----- Original Message -----
> > > > From: "Lynn" <lynn.khalife@>
> > > > Sent: Thursday, July 10, 2008 8:30:06 AM (GMT-0800) America/
> > > Los_Angeles
8.03.404
> > > > Dear Kevin:
> > > > I'm not sure I understand your first sentance. The global BAQ
> was
> > > > created in company A, so it has a BAQ ID of A-BOM. The
company
> > > which
> > > > will not recognize it is CORE. So, when I try to re-import
the
> A-
> > > > BOM.xml into company CORE and name it A-BOM, I get an error
> > message
> > > > that the prefix must be CORE-.
> > > > I tried importing it as CORE-BOM and copying it to A-BOM, but
> > > Vantage
> > > > will not allow me to copy from one prefix to another.
> > > > I need the BAQ ID to be A-BOM because it is used in a BAQ
> Report
> > > > which I have placed on the Vantage menu.
> > > > Regarding the setup of the Db's, is there someplace other
than
> > > > External Company Maintenance which will affect the use of
BAQs
> in
> > > > multiple companies?
> > > > Thanks.
> > > > Lynn
> > 40yahoogroups.com> .com ,
> > > "Kevin Kadamus" <kkadamus@> wrote:
> > > > > Lynn,
> > > > > Make sure that you have properly copied (made a back-up) of
> > your
> > > > BAQ and
> > > > > then add them to the missing companies.
> > > > > Depending on how your IT has set up your Db's you will need
> to
> > > make
> > > > sure the
> > > > > BAQ is in all of them.
> > > > > You can set up BAQ's to be in one, two, all, etc. It is up
to
> > you
> > > > how you
> > > > > want to configure your Db's.
> > > > > Thank you,
> > > > > Kevin Kadamus
> > > > > Senior Consultant
> > > > > kkadamus@
> > > > > 952-905-0387
> may
> > > > contain
> > intended
> > > > only for
use,
> > > > distribution,
> person
> > > or
> > > > entity is
in
> > > error,
> > > > please
> > > > > notify the sender by telephone at 952-905-0387 .
> > > > > _____
> > > [mailto: vantage@yahoogroups <mailto:vantage%
> > 40yahoogroups.com> .com ]
> > > On
> > > > Behalf Of
> > > > > Lynn
> > > > > Sent: Thursday, July 10, 2008 10:13 AM
> > > > > Subject: [Vantage] BAQ -- Multi-Company -- Vantage 8.03.404
> > > > > We have 5 companies set up in our databases. Four of the
> > > companies
> > > > > are associated with one another.
> > > > > I created a BAQ in my Training database. I then imported it
> > into
> > > > the
> > > > > Live database.
> > > > > The BAQ worked fine in all 4 of the companies in the
Training
> > > > > database.
> > > > > However, it works in only 3 of the companies of the Live
> > > database.
> > > > > In the 4th company, it does not appear on the BAQ search
list
> > at
> > > > all.
> > > > > This company is associated in External Company Maintenance
> and
> > I
> > > am
> > > > > able to view other BAQs from the other companies -- just
not
> > this
> > > > BAQ.
> > > > > Can anyone give me a clue to what the problem might be?
> > > > > The BAQ is for my Crystal Reports BOM which links 9 tables
so
> I
> > > > don't
> > > > > really want to create a separate one just for this one
> stubborn
> > > > > company.
> > > > > Lynn
> > > > > [Non-text portions of this message have been removed]
We have 5 companies set up in our databases. Four of the companies
I created a BAQ in my Training database. I then imported it into the
Live database.
The BAQ worked fine in all 4 of the companies in the Training
database.
However, it works in only 3 of the companies of the Live database.
In the 4th company, it does not appear on the BAQ search list at all.
This company is associated in External Company Maintenance and I am
able to view other BAQs from the other companies -- just not this BAQ.
The BAQ is for my Crystal Reports BOM which links 9 tables so I don't
really want to create a separate one just for this one stubborn
company.
Lynn
Lynn,
Make sure that you have properly copied (made a back-up) of your BAQ and
Depending on how your IT has set up your Db's you will need to make sure the
You can set up BAQ's to be in one, two, all, etc. It is up to you how you
Thank you,
Kevin Kadamus
Senior Consultant
kkadamus@...
952-905-0387
CONFIDENTIALITY NOTICE: This electronic email transmission may contain
consultant/client privilege and confidential information intended only for
the individual or entity named above. Any dissemination, use, distribution,
copying or disclosure of this communication by any other person or entity is
strictly prohibited. Should you receive this transmission in error, please
_____
Lynn
Live database.
database.
company.
Lynn
Dear Kevin:
I'm not sure I understand your first sentance. The global BAQ was
created in company A, so it has a BAQ ID of A-BOM. The company which
will not recognize it is CORE. So, when I try to re-import the A-
BOM.xml into company CORE and name it A-BOM, I get an error message
I tried importing it as CORE-BOM and copying it to A-BOM, but Vantage
I need the BAQ ID to be A-BOM because it is used in a BAQ Report
Regarding the setup of the Db's, is there someplace other than
External Company Maintenance which will affect the use of BAQs in
multiple companies?
Thanks.
Lynn
> Lynn,
BAQ and
sure the
how you
> Thank you,
> Kevin Kadamus
> Senior Consultant
> kkadamus@...
> 952-905-0387
contain
only for
distribution,
entity is
please
> _____
Behalf Of
> Lynn
the
> Live database.
> database.
all.
BAQ.
don't
> company.
> Lynn
Lynn & Kevin -
I am running into the same issue. CompanyA & CompanyB both want the BAQ names to be A-xxx and B-xxx. I created the original BAQ (A-rpt) in Company A. I can export/import, but it wants it to be B-rpt. Although, I have checked the Global box and I can see it in company B in Report Designer. If I choose A-rpt. It tells me the BAQ does not exist.
I will have to do this for several reports and do not want to recreate the BAQ, etc. over and over again.
I am new to Vantage, so if there is a setup issue, can someone please explain it to me?
Like Lynn, I do not want to have to waste time doing recreation.
Thanks!
jen
Sent: Thursday, July 10, 2008 8:30:06 AM (GMT-0800) America/Los_Angeles
Dear Kevin:
multiple companies?
Thanks.
Lynn
--- In vantage@yahoogroups.com , "Kevin Kadamus" <kkadamus@...> wrote:
> Lynn,
BAQ and
sure the
how you
> Thank you,
> Kevin Kadamus
> Senior Consultant
> kkadamus@...
> 952-905-0387
contain
only for
distribution,
entity is
please
> _____
> From: vantage@yahoogroups.com [mailto: vantage@yahoogroups.com ] On
Behalf Of
> Lynn
the
> Live database.
> database.
all.
BAQ.
don't
> company.
> Lynn
Nigel.
--- In vantage@yahoogroups.com, Jennifer George <jgeorge@...> wrote:
> Lynn & Kevin -
BAQ does not exist.
> Thanks!
> jen
> From: "Lynn" <lynn.khalife@...>
Los_Angeles
> Dear Kevin:
which
Vantage
> multiple companies?
> Thanks.
> Lynn
> --- In vantage@yahoogroups.com , "Kevin Kadamus" <kkadamus@> wrote:
> > Lynn,
> BAQ and
make
> sure the
> how you
> > Thank you,
> > Kevin Kadamus
> > Senior Consultant
> > kkadamus@
> > 952-905-0387
> contain
> only for
> distribution,
or
> entity is
error,
> please
> > _____
On
> Behalf Of
> > Lynn
companies
> the
> > Live database.
> > database.
database.
> all.
am
> BAQ.
> don't
> > company.
> > Lynn
That is true in 8.03.4xx. Before, you didn't have to have Sonic for Global
BAQ. Also, in order to access the BAQ on a dashboard in other companies,
your users must be set up with the appropriate "external companies" in User
Maintenance and they will have to sign into the other company every time the
Daniel Laidig
<mailto:daniellaidig@...> daniellaidig@...
_____
Nigel Kerley
Nigel.
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, Jennifer
> Lynn & Kevin -
BAQ does not exist.
> Thanks!
> jen
Los_Angeles
> Dear Kevin:
which
Vantage
> multiple companies?
> Thanks.
> Lynn
> --- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com ,
> > Lynn,
> BAQ and
make
> sure the
> how you
> > Thank you,
> > Kevin Kadamus
> > Senior Consultant
> > kkadamus@
> > 952-905-0387
> contain
> only for
> distribution,
or
> entity is
error,
> please
> > _____
[mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com ]
On
> Behalf Of
> > Lynn
companies
> the
> > Live database.
> > database.
database.
> all.
am
> BAQ.
> don't
> > company.
> > Lynn
We do have Sonic installed and running. I know its working because I
I didn't know about the "External Companies" in User Maintenance so I
Then I rebooted Vantage, logged back in to CORE and tried to see the
What makes this so puzzling is that when I am in company CORE, I can
use other A- BAQs. It is only this one I cannot see, which happens
Thanks for educating me on the user maintenance requirement for the
Lynn
--- In vantage@yahoogroups.com, "Daniel Laidig" <daniellaidig@...>
for Global
companies,
in User
time the
> Daniel Laidig
> _____
Behalf Of
> Nigel Kerley
> Nigel.
Jennifer
> > Lynn & Kevin -
> BAQ does not exist.
> > Thanks!
> > jen
> Los_Angeles
> > Dear Kevin:
> which
message
> Vantage
> > multiple companies?
> > Thanks.
> > Lynn
> > > Lynn,
your
> > BAQ and
> make
> > sure the
you
> > how you
> > > Thank you,
> > > Kevin Kadamus
> > > Senior Consultant
> > > kkadamus@
> > > 952-905-0387
> > contain
intended
> > only for
> > distribution,
> or
> > entity is
> error,
> > please
> > > _____
> On
> > Behalf Of
> > > Lynn
> companies
into
> > the
> > > Live database.
> > > database.
> database.
at
> > all.
I
> am
this
> > BAQ.
> > don't
> > > company.
> > > Lynn
Pardon my ignorance, please. What is Sonic? Is it an add-on or is it an option?
Secondly, how can I tell if we have it or not?
Thanks!
jen
Sent: Friday, July 11, 2008 5:49:07 AM (GMT-0800) America/Los_Angeles
Lynn
--- In vantage@yahoogroups.com , "Daniel Laidig" <daniellaidig@...>
for Global
companies,
in User
time the
> Daniel Laidig
> _____
Behalf Of
> Nigel Kerley
> Nigel.
Jennifer
> > Lynn & Kevin -
> BAQ does not exist.
> > Thanks!
> > jen
> Los_Angeles
> > Dear Kevin:
> which
message
> Vantage
> > multiple companies?
> > Thanks.
> > Lynn
> > > Lynn,
your
> > BAQ and
> make
> > sure the
you
> > how you
> > > Thank you,
> > > Kevin Kadamus
> > > Senior Consultant
> > > kkadamus@
> > > 952-905-0387
> > contain
intended
> > only for
> > distribution,
> or
> > entity is
> error,
> > please
> > > _____
> On
> > Behalf Of
> > > Lynn
> companies
into
> > the
> > > Live database.
> > > database.
> database.
at
> > all.
I
> am
this
> > BAQ.
> > don't
> > > company.
> > > Lynn
Sorry, I can't answer those questions. Someone else did the
installation of Vantage and presented me with a working install on my
pc. I don't know anything about Sonic other than Vantage uses it for
multi-company data transfer.
I can see that it is installed by going to this menu:
System Management -- External System Integration -- External Company
Maintenance. Then in the box for External System, I select Multi-
Company, and SONIC automatically shows up as the Transfer method.
Then I do a Search for External Company ID and I see that my other
companies are on the list.
And I know that SONIC is doing its job because other BAQs that we
have created in the various companies do appear and work in multiple
companies.
Your network administrator or whoever did your Vantage install should
be able to answer your questions about SONIC.
Please let me know if you also place a Support call in with Epicor.
Lynn
it an option?
> Thanks!
> jen
America/Los_Angeles
I
I
the
can
> Lynn
> --- In vantage@yahoogroups.com , "Daniel Laidig" <daniellaidig@>
> for Global
> companies,
companies"
> in User
every
> time the
> > Daniel Laidig
> > _____
On
> Behalf Of
> > Nigel Kerley
> > Nigel.
> Jennifer
> > > Lynn & Kevin -
(A-
> > BAQ does not exist.
recreation.
> > > Thanks!
> > > jen
> > Los_Angeles
> > > Dear Kevin:
was
> > which
A-
> message
> > Vantage
Report
in
> > > multiple companies?
> > > Thanks.
> > > Lynn
> > > > Lynn,
> your
> > > BAQ and
to
> > make
> > > sure the
> you
> > > how you
> > > > Thank you,
> > > > Kevin Kadamus
> > > > Senior Consultant
> > > > kkadamus@
> > > > 952-905-0387
may
> > > contain
> intended
> > > only for
> > > distribution,
person
> > or
> > > entity is
> > error,
> > > please
> > > > _____
> > On
> > > Behalf Of
> > > > Lynn
> > companies
> into
> > > the
> > > > Live database.
> > > > database.
> > database.
> at
> > > all.
and
> I
> > am
> this
> > > BAQ.
I
> > > don't
stubborn
> > > > company.
> > > > Lynn
One other thing that you have to do is run the MultiCompany Server Process
for Sonic to be able to pick up your newly created BAQ and transfer it to
Daniel Laidig
_____
Lynn
Lynn
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Daniel
for Global
companies,
in User
time the
> Daniel Laidig
> _____
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf Of
> Nigel Kerley
> Nigel.
Jennifer
> > Lynn & Kevin -
> BAQ does not exist.
> > Thanks!
> > jen
> Los_Angeles
> > Dear Kevin:
> which
message
> Vantage
> > multiple companies?
> > Thanks.
> > Lynn
> > > Lynn,
your
> > BAQ and
> make
> > sure the
you
> > how you
> > > Thank you,
> > > Kevin Kadamus
> > > Senior Consultant
> > > kkadamus@
> > > 952-905-0387
> > contain
intended
> > only for
> > distribution,
> or
> > entity is
> error,
> > please
> > > _____
> On
> > Behalf Of
> > > Lynn
> companies
into
> > the
> > > Live database.
> > > database.
> database.
at
> > all.
I
> am
this
> > BAQ.
> > don't
> > > company.
> > > Lynn
Looks like I need to find some really good documentation on this.
I started here about 3 weeks ago. They had a consultant come in and do the install.
Unfortunately, it seems like no one really knows what he did.
So, I am trying to figure this all out.
I have gotten all the User Guides. Unfortunately, I don't see any documentation on Setup.
I guess that is what I am going to have to find.
Thank you all for the help and insight!
Sent: Friday, July 11, 2008 7:56:41 AM (GMT-0800) America/Los_Angeles
companies.
Lynn
it an option?
> Thanks!
> jen
America/Los_Angeles
I
I
the
can
> Lynn
> for Global
> companies,
companies"
> in User
every
> time the
> > Daniel Laidig
> > _____
On
> Behalf Of
> > Nigel Kerley
> > Nigel.
> Jennifer
> > > Lynn & Kevin -
(A-
> > BAQ does not exist.
recreation.
> > > Thanks!
> > > jen
> > Los_Angeles
> > > Dear Kevin:
was
> > which
A-
> message
> > Vantage
Report
in
> > > multiple companies?
> > > Thanks.
> > > Lynn
> > > > Lynn,
> your
> > > BAQ and
to
> > make
> > > sure the
> you
> > > how you
> > > > Thank you,
> > > > Kevin Kadamus
> > > > Senior Consultant
> > > > kkadamus@
> > > > 952-905-0387
may
> > > contain
> intended
> > > only for
> > > distribution,
person
> > or
> > > entity is
> > error,
> > > please
> > > > _____
> > On
> > > Behalf Of
> > > > Lynn
> > companies
> into
> > > the
> > > > Live database.
> > > > database.
> > database.
> at
> > > all.
and
> I
> > am
> this
> > > BAQ.
I
> > > don't
stubborn
> > > > company.
> > > > Lynn
for Continuous Processing, 1 minute delay, Schedule "Now", and there
is a log filename.
task.
sure am learning a lot about multi-company data transfers for future
reference.
Lynn
Process
it to
> Daniel Laidig
> _____
Behalf Of
> Lynn
I
I
the
can
> Lynn
> for Global
> companies,
companies"
> in User
every
> time the
> > Daniel Laidig
> > _____
> Behalf Of
> > Nigel Kerley
> > Nigel.
> Jennifer
> > > Lynn & Kevin -
(A-
> > BAQ does not exist.
> > > Thanks!
> > > jen
> > Los_Angeles
> > > Dear Kevin:
was
> > which
A-
> message
> > Vantage
Report
in
> > > multiple companies?
> > > Thanks.
> > > Lynn
> > > > Lynn,
> your
> > > BAQ and
to
> > make
> > > sure the
> you
> > > how you
> > > > Thank you,
> > > > Kevin Kadamus
> > > > Senior Consultant
> > > > kkadamus@
> > > > 952-905-0387
may
> > > contain
> intended
> > > only for
> > > distribution,
person
> > or
> > > entity is
> > error,
> > > please
> > > > _____
> > On
> > > Behalf Of
> > > > Lynn
> > companies
> into
> > > the
> > > > Live database.
> > > > database.
> > database.
> at
> > > all.
and
> I
> > am
> this
> > > BAQ.
I
> > > don't
stubborn
> > > > company.
> > > > Lynn
Lynn,
You seem to be on the right track; however you will need to know if you have
I would recommend a call to your CAM to see if you can get any "free"
There are several ways to set up what you are doing. I have clients that
have Multi-site / multi-companies that only allow global BAQ's for some of
their divisions while others are completely independent of each other. That
is why I was asking you how you have set up your Db's. There are many
decisions to make when you set up your multi-company solution. Without
seeing how you are set up I can only speculate what may or may not be set up
Are you running SQL or just Progress? You have other options depending on
how you set up your environment, one server, multiple servers, SANS, etc. It
Good luck on your quest for multi-company knowledge! You can give me a call
Thank you,
Kevin Kadamus
Senior Consultant
kkadamus@...
952-905-0387
_____
Lynn
is a log filename.
task.
reference.
Lynn
Process
it to
> Daniel Laidig
> _____
Behalf Of
> Lynn
I
I
the
can
> Lynn
> for Global
> companies,
companies"
> in User
every
> time the
> > Daniel Laidig
> > _____
> Behalf Of
> > Nigel Kerley
> > Nigel.
> Jennifer
> > > Lynn & Kevin -
(A-
> > BAQ does not exist.
> > > Thanks!
> > > jen
> > Los_Angeles
> > > Dear Kevin:
was
> > which
A-
> message
> > Vantage
Report
in
> > > multiple companies?
> > > Thanks.
> > > Lynn
> > > > Lynn,
> your
> > > BAQ and
to
> > make
> > > sure the
> you
> > > how you
> > > > Thank you,
> > > > Kevin Kadamus
> > > > Senior Consultant
> > > > kkadamus@
> > > > 952-905-0387
may
> > > contain
> intended
> > > only for
> > > distribution,
person
> > or
> > > entity is
> > error,
> > > please
> > > > _____
> > On
> > > Behalf Of
> > > > Lynn
> > companies
> into
> > > the
> > > > Live database.
> > > > database.
> > database.
> at
> > > all.
and
> I
> > am
> this
> > > BAQ.
I
> > > don't
stubborn
> > > > company.
> > > > Lynn
