BAQ - Next Operation per Resource Group
Hello!
Looking to create a BAQ that shows me JUST the next operation at each resource group.
I have created a BAQ showing all Operations per Resource Group that are due to start today, but now I want to limit that (or group) so that I ONLY see operations that are first for that given machine.
ie: Current
RG: 101 - Op20 - Start 7:00am
RG: 101 - Op30 - Start 8:00am
RG: 101 - Op40 - Start 9:00am
RG: 201 - Op10 - Start 7:00am
RG: 201 - Op60 - Start 8:00am
RG: 201 - Op10 - Start 9:00am
future:
Creating a subquery to filter on is difficult because it would need to link to the ResourceGroup table for the grouping, and also the JobOper table for the start time.
Any help would be appreciated!
I mocked up something that will get a row number and then in your dashboard you can filter only for row 1. I also made it as a subquery and then filtered the main by row 1.
ROW_NUMBER() OVER (PARTITION BY JobOpDtl.ResourceGrpID ORDER BY JobOper,StartDate,JobOper.StartHour)
E10JobOpByRG.baq (41.8 KB)
Hi Greg! Much appreciate the response. Seeing that I am on 10.1.500, the import of your file didn’t work.
I was able to add the calculated field as you’ve shown above, and it worked perfectly. Now, instead of creating a filter when viewing the dashboard (baq), it rather it automatically just show Rows = 1. Is that where the subquery comes in?
Is there any chance at all you’d be willing to take just a few screenshots so I can build myself. It would be a life saver.
Thanks!
There is a way to change the version, by changing extension to zip and then opening the baq and updating the version.
Inner sub query
rownum
Top level using sub to filter for only row 1
JobOpDtl criteria is = 10 and I just did released and no completed jobs.
