BAQ or User Error in 9.05.600C?
PayRollDate and ClockInDate give the same results. Nothing.
I changed the parameters from:
DataType: Date
Format: x(8)
Mandatory: Yes (Checked)
Editor Type: Common Editor
To this:
DataType: Date
Format: 99/99/99
And this:
DataType: DateTime
Format: 99/99/99 HH:MM:SS.SSS
The latter is how it is stored in the SQL tables.
Neither works.
Jeff Sanders
--- In vantage@yahoogroups.com, "Scott Litzau" <scott.litzau@...> wrote:
> I think you want to use ClockInDate field as the parameter, not the
> PayRollDate.
> Scott
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> jeffery_p_sanders
> Sent: Monday, August 23, 2010 10:21 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] BAQ or User Error in 9.05.600C?
> I inserted the LaborHed and LaborDtl tables in the phrase builder. They are
> linked. I displayed fields and analyzed\tested the BAQ. Everything works
> fine. The results show about 10 records inbetween the 8/12/2010 and
> 8/20/2010 Payroll dates.
> Next I place two criteria on the LaborDtl table:
> Criteria 1
> Field Name: PayRollDate
> Comparison: >=
> Filter Value: {StartDate} Specified Parameter
> Criteria 2
> And Or: And
> Comparison: <=
> Filter Value: {EndDate} Specified Parameter
> I defined the Parameters as:
> DataType: Date
> Format: x(8)
> When I run the BAQ, it asks me for the start and end dates. I select them
> as 8/1/2010 and 8/31/2010. I get no results or errors.
> What am I doing wrong?
> Jeff Sanders
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
I inserted the LaborHed and LaborDtl tables in the phrase builder. They are linked. I displayed fields and analyzed\tested the BAQ. Everything works fine. The results show about 10 records inbetween the 8/12/2010 and 8/20/2010 Payroll dates.
Criteria 1
Comparison: >=
Criteria 2
And Or: And
Comparison: <=
DataType: Date
Format: x(8)
When I run the BAQ, it asks me for the start and end dates. I select them as 8/1/2010 and 8/31/2010. I get no results or errors.
Jeff Sanders
PayRollDate.
Scott
jeffery_p_sanders
Criteria 1
Comparison: >=
Criteria 2
And Or: And
Comparison: <=
DataType: Date
Format: x(8)
Jeff Sanders
