I have a BAQ that have the PartPlant link to PartCost. I added a parameter for “Plant” and it seems to be working fine in BAQ Designer when testing. It also seems to be working fine when I am in the Dashboard Designer. However as soon as I deploy it and try to filter by the parameter for plant, I am getting blank results. If I don’t put in any plant and select all plants, then it shows. Any ideas? First time I ever had this issue.
Are you in the exact same plant when testing? Are you positive there aren’t other filters on the BAQ or Dashboard that could cause this?
I am in the exact company/plant when running the “Plant” parameter for just that plant. I tested the Dashboard in designer mode and it worked. There are no other parameters. It’s just when I deployed that it will not display which is odd. The BAQ itself worked as well.
I end up setting the dashboard as runtime and seems to be working. Not sure why there’s issue with setting the dashboard as assembly. Never had this happened before.
