BAQ / Part Maintenance
Try disabling all of your part maintenance BPMs, then make sure that changing the description and saving works. Then enable your BPMs one at a time, re-testing that the change and save works after each one. Hopefully this will help you find the culprit. Once you find it, post the details and maybe someone in the group can help spot your problem.
--- In vantage@yahoogroups.com, "VantageUser13" <vantageuser13@...> wrote:
> I have several BPM for the maintenance part, when I activate my all BPM and I'll make updates on my plays and I save my save does not work. For example I change the description and when I save nothing is saved, yet I do not have BPM on the description. Why BPM prevent me from making saves??
> Vantage 8.03.408b
Vantage 8.03.408b
