Anyone have an idea on where I should start looking to correct this?
Here is the full error message is that helps.
Thanks in advance.
Exception caught in: Epicor.Mfg.BO.ReportMonitor
Error Detail
Message: Record has been modified by another user and couldn't be updated. Please press the Refresh button and re-enter your changes.
Type: UpdateConflict
Program: core/BizRuleEngine.p
Method: Main-Block
Table: SysRptLst
Row: 0x0000000009013a22
Field: SysRevID
Stack Trace
at Epicor.Mfg.Proxy.ReportMonitorImpl.Update(ReportMonitorDataSet ds)
at Epicor.Mfg.UI.Adapters.ReportMonitorAdapter.Update()
at Epicor.Mfg.UI.App.SysMonitorEntry.Transaction.ProcessAutoPrintRequests()
Inner Exception
ERROR condition: The Server application has returned an error. (7243) (7211)
Inner Stack Trace
at Progress.Open4GL.DynamicAPI.Session.runProcedure(String requestID, String procedureName, ParameterSet parms, Boolean persistent, Boolean internal_Renamed, Int64 procId, MetaSchema localSchema, Int32 stateModel)
at Progress.Open4GL.DynamicAPI.Session.runStatelessProcedure(String requestID, String fullProcedureName, ParameterSet inparams, Object procId, MetaSchema localSchema, Int32 stateModel)
at Progress.Open4GL.DynamicAPI.PersistentProc.runTheProcedure(String requestID, String procedureName, ParameterSet parms, MetaSchema schema)
at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String procedureName, ParameterSet parms, MetaSchema schema)
at Epicor.Mfg.Core.CallContext.CallContextPersistentProc.runProcedure(String procedureName, ParameterSet parameters, MetaSchema metaSchema)
at Epicor.Mfg.Core.CallContext.ProxyHelper.CallMethod(String procedureName, ParameterSet parameters, MetaSchema metaSchema, BLConnectionPool connPool, Session connection, PersistentProc persistProc, CallContextDataSet callContextDataSet)
