BAQ Report Designer & BAQReportParameter
Thanks Scott,
I would have never thought to use a Form Customization to add the
controll to feed the ReportParam fields.
Thanks again,
Calvin
--- In vantage@yahoogroups.com, "Scott Litzau" <scott.litzau@...>
wrote:
> The general steps I follow are:
> 1. Create BAQ
> 2. Create BAQ Report in Report Designer
> - Create Form
> - Create Crystal Report with the field\parameter
> (ReportParam.Checkbox01) you want to in the report
> 3. Deploy Crystal Report
> 4. Place BAQ Report into Menu
> 5. Go out and back into Vantage to have Report show in Menu
> 6. Go into Developer Mode
> 7. Run Report
> 8. Go into Customization
> 9. Open Toolbox and add Fields wanted, in this case a checkbox,
and tie to
> ReportParam.checkbox01
> 10. Save Customization
> 11. Go into Menu Maintenance for Report and update to the
customization you
> just created
> Now the user runs the report and the field will be on the Form and
will be
> used in the report
> Scott Litzau, MCP
> Olympus Flag & Banner
> Information Systems Manager
> scott.litzau@...
> P: 414-365-9732
> F: 414-355-1931
> -----Original Message-----
Behalf Of
> Calvin Krusen
> Sent: Monday, March 10, 2008 12:36 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] BAQ Report Designer & BAQReportParameter
> How do I place a control on a BAQ Report Dialog window, that feeds
the
> BAQReportParameter.Check01 (or other fields in the
BAQReportParameter
> table) field for computation in Crystal Reports?
> What I'm actully trying to do is to creat a report that lists our
> customers, with the option of listing only the customer records
that
> have a blank city field.
> I could easily make the BAQ return only records with a blank city
> field, but want to make the report a little more dynamic. This is
> more of an exercise in creating a BAQ Report for others to use.
> Thanks in advance,
> Calvin
must have
Builder and
> Yahoo! Groups Links
How do I place a control on a BAQ Report Dialog window, that feeds the
BAQReportParameter.Check01 (or other fields in the BAQReportParameter
customers, with the option of listing only the customer records that
Thanks in advance,
Calvin
1. Create BAQ
- Create Form
7. Run Report
9. Open Toolbox and add Fields wanted, in this case a checkbox, and tie to
11. Go into Menu Maintenance for Report and update to the customization you
just created
Now the user runs the report and the field will be on the Form and will be
used in the report
Scott Litzau, MCP
scott.litzau@...
P: 414-365-9732
F: 414-355-1931
Calvin Krusen
Thanks in advance,
Calvin
Yahoo! Groups Links
