You can customize these the same as other menu options.
Turn on developer mode and launch the report, then once the report screen is up pick Tools/Customization.
Then set the sharedprops.enabled on "PrintTool", "PrintPreviewTool", "GenerateTool" and "ProcessTool" to false when you do not have a valid value entered.
this.baseToolbarsManager.Tools["PrintTool"].SharedProps.Enabled = false;
set it to true once you have valid values
Jim Kinneman
Encompass Solutions, Inc
Jim Kinneman
--- In vantage@yahoogroups.com, "mike.numbers" <mnumbers@...> wrote:
> Epicor 9.04.507a
> I have created a report through the BAQ Report Designer. I have created 2 options so the user can run the report by limits and the limits are Part Numbers. The problem I have is when the user does not enter anything for the limits we get the system error--"Object Reference not set to an instance of an object" followed by "Tried to call a method in an invalid procedure (7224)". When limits are entered correctly, the report prints as designed. My question is.. is there a way to edit the options on this to prevent the user from running the report without entering the options?
