BAQ Report Designer Sample Data
I'm selecying just a single order and it is taking forever to execute.
--- In vantage@yahoogroups.com, Roel Martinez <rmartinez@...> wrote:
> Hello Anitha.
> Filter in BAQRpt Designer actually selects records based on it. They pass through to your Crystal report as BAQReportParameters (In Field Explorer / Crystal), but if you selected multiple values it is very difficult to parse-out the string that transfers from Vantage (BAQReportParameters.Filter1 for example).
> Now, Options are different as you tipically ENTER discrete values in the assigned fields or prompts.... (for instance If you create an Option field with BAQReportParameters.Character05). You can retrieve these values in general and utilize them to design your Crystal Report.
> Regards.
> Roel Martinez
> ERP Analyst
> SABRE TUBULAR STRUCTURES (tm)
> www.sabretubularstructures.com<http://www.sabretubularstructures.com/>
> 8653 E. Hwy 67 | Alvarado, TX 76009
> Phone: 817-852-1700 ext. 11858 | Direct Line: 817-852-1858 |Fax: 817-852-1705
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Anitha
> Sent: Friday, March 18, 2011 3:30 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: BAQ Report Designer Sample Data
> Hi,
> I set up filter order# in BAQ Report Designer.How do I link this order number to my crystal report?
> Thanks.
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Brian W. Spolarich" <bspolarich@> wrote:
> > That's what the 'Sample Data' feature does. I recommend previewing
> > the BAQ Report form, generating some real data (enter your report
> > options and select the 'Generate Only' option), and use a full dataset
> > to design your report. This gives you a much better idea how your data
> > is going to work anyways, in terms of column width, grouping, etc.
> > -----Original Message-----
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
> > Of Anitha
> > Sent: Friday, March 18, 2011 3:12 PM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] BAQ Report Designer Sample Data
> > My BAQ Report Designer's sample data is just fetching one record in
> > Crystal Report.Am I missing something?
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
My BAQ Report Designer's sample data is just fetching one record in Crystal Report.Am I missing something?
Of Anitha
Hi,
Thanks.
> Of Anitha
If the user puts in an order number, only data for that order will be in the xml file that is used by Crystal. If they do not use the filter, all order numbers will be in the xml file that is used by Crystal.
Hi,
Thanks.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Brian W. Spolarich" <bspolarich@...> wrote:
> Of Anitha
My BAQ report preview is taking forever to execute when I use filter.AM I doing something wrong?
> Hi,
> Thanks.
> > Of Anitha
Hello Anitha.
Regards.
Roel Martinez
ERP Analyst
Hi,
Thanks.
> Of Anitha
